We have a Makino sinker with the MGH pc front end control. This thing has sat off for about 5 years. We replaced the batteries, re generated the control with a procedure from Makino. The PC now boots up with overtravel warnings. Makino also sent parameters and a procedure to install them. We can load the parameters in to the control, set the file to the active disk side, go to run, select the program O0001, but when we hit run, nothing happens. We have made several attempts at it, but the run will just not work. If we hit run in manual or macro, the machine will fault as expected. Anyone know this control?
