I am looking for a kit, or plans for a DIY CNC project, however there are many out there and I am wondering what peoples experiences are like for a few of them.
I am also in Australia, so often shipping on kits from OS will kill the price on a lot of parts that I can buy.
Minimum Requirements:
-1200mmx2400mm [4'x8'] X by Y
-150mm of Z travel [6'']
The machine will be used for wood cutting for the most part, with maybe some plexi and aluminium cutting/engraving.
[Have you looked at the Mechmate plans?
MechMate CNC Router - Build your own with our detailed plans That seems like a sturdier machine than most, although I'm not sure it has that much Z travel.]
Budget:
I am a student, and on a budget, so ideally I would like to go about it as cheaply as possible. I can get parts machined locally if that helps with the overall cost of things.
[It's hard to see how it would; custom machining is not usually cheap, unless you've got a machinist pal who works for beer.]
-$3000 is the amount that I would like to keep it under.
[That's going to be difficult, especially if you're buying a kit. Your best bet might to start scrounging around for used machines to cannibalize, and work out a plan around what you manage to find.]
Other Considerations:
-The ability to add a 4th axis later down the track would be excellent, but isn't necessary. If it were possible to add on later, my z travel would have to be much larger.
I would probably need
at least a part of 500mm [5/3'] diameter to be able to fit.
How feasible is this, and will I lose precision by having a larger z travel? How much of an issue will this be?
[Adding length to your Z axis will decrease the rigidity of your machine, all things being equal. But if you go with a sunken rotary axis, where the center of the A axis is at the height of your bed, then you can add it without raising Z. That's part of the advantage to designing a machine yourself - you can accommodate things like this.]
I know there are a few kits that are made from CNC cut ply board. I am concerned slightly that such designs over time will begin to warp/lose accuracy. Is this a possibility, or should I not worry about it?
[Yes, it is a possibility. A metal structure would be better; plywood designs are just easier for most people to build. If you are going to use plywood, use a good grade of it, like the kind used for marine applications (lots of layers, no voids). Think in terms of torsion boxes, rather than depending on single sheets for stiffness.]
Dust extraction and the like is not to come under the budget. Only things directly integrated into the router are to be taken as a part of it [ie stepper motors, spindle, bits, suction area to hold work down, etc]
[You'd be doing well to just get the router done within your budget. Things like tooling and vacuum hold-downs are extra costs to deal with after it's complete.]
Ryan
