how to adjust or set the parameter for tail stock soft limit for OKUMA LB35
As normal for NC axis, if there is one ( W ?) specified.
Maybe you need <Extend> (F8 on most OSP) on parameter operator limit page, if "W axis" is not displayed.
is it OSP7000?
I am having a similar issue. I have a tailstock on my lb35II. When I go into system parameters I only see X and Z. No W. I hit the page down to make sure it wasn't on a different page like the Turret parameters. Please help. As soon as I engage the tailstock with the push pin I only can move Z-. It will not move Z+. I am wondering if there is a parameter to change allowing me to adjust the end limits for the W axis. Thanks for any help.
If its a push pin type (manual tow Along) its not a w axis. There should be a park parameter in the tailstock page.
