585,981 active members*
4,151 visitors online*
    Oct 2010
    62
    Tool library not showing in operations
    I have created a tool library in Solidcam.
    In a new milling operation I go to the 'Tool' category out of the options on the left. I then click on 'Select'. A table comes up which has the headings 'Tool number', 'ID number' 'User definition' etc. However this table is blank. I then go to 'Import tools' and my tool library appears. However nothing happens when I go to import them.
    How do I go about using my tool library in milling operations?
    Mar 2013
    12
    Try:
    1) "Tools" then 2) "select" then 3) "import tools" then 3) "library"
    This should work for you.
    May 2013
    37
    walk into the tool table and select IMPORT then select the tool.
    To use this utility to be run you double-click the left mouse button.
    You can also file *. prp your machine add:
    @ pre_processor
    **** tool_table_name = YOU_TABLE_NAME
    Sorry for my english
  1. SprutCAM Tool Library tool numbers
    By MichaelHenry in forum SprutCAM
    Last Post: 06-29-2016, 02:30 PM
  2. Tool Path & Operations
    By badoxygeno2 in forum BobCad-Cam
    Last Post: 11-20-2012, 09:09 PM
  3. CNC Tool Library (Creation of ISO 30 Tool Holders)
    By ender_wiggen in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-27-2012, 08:59 AM
  4. Holders Not Showing in Tool Library
    By dkaustin in forum SprutCAM
    Last Post: 05-25-2011, 12:25 AM
  5. tool library...or is it?
    By brooklynmetal in forum BobCad-Cam
    Last Post: 06-16-2008, 07:34 PM
