585,908 active members*
3,812 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Where can I find Xilog software?
Page 2 of 3 123
Results 21 to 40 of 42
  1. #21
    Aug 2014
    13
    Re: Where can I find Xilog software?
    Thank you Barada...very uselfull info. However..the NC is working fine, I have already loaded the PLC and PAR files previously using a similar schematic. The big issue is that I cannot get the NC to read a .PGM file....I keep getting the error "Invalid File Format"
    More searching over the internet leads me to believe that this old NC requires a file called cnvrt1.1.exe to convert to PGM files and not WinXiso
  2. #22
    Aug 2014
    13
    Thanks for that Service SCM BR....the problem is not the PLC and PAR files...it is to get the NC to open/edit .PGM file created with Xilog.
  3. #23
    Jan 2015
    We are a little carpenter's workshop (3 coworkers) and we have purchased an old machine at auction module. We had expectations improving our productivity, but sincerely, we have no idea how we could optimize times programing our machine out of TRIA7500. We can only program it by typing out the manually in the machine consuming excessive time.
    Is Xilog the appropriate software to be able to program our machine in an easier way?
    Where could find the necessary software?
    How to install Xilog on my PC?
    Do exist a manual or tutorial for Xilog?
    Is it necessary to downgrade the OS to 32bits in order to use Xilog?
    Thank you in advance!
    Machine: Morbidelli 503
    Year: 1997
    Serial Number: AL3514
  4. #24
    Aug 2014
    13
    @AntonioC
    We purchased the A213 (tria7500) a while back on auction and took me 2 months and countless hours on the net to figure this out.
    For our NC, xilog and xilog plus does not work as the NC does not recognise the .PGM file format.
    This is how we resolved it:
    1. We open the .DXF file in Aphacam and save it as .ANC file.
    2. We rename the .ANC file to .TXT file
    3. then we use the CN75NEW.exe file, run in DOS mode to convert the .TXT file to .PGM
    4. We then send the file via NULL-MODEM cable to NC
    5. Open the file in EDITOR on NC and verify it.
    Done..
    Hope this helps...send me an email if you require more info or any of the files etc
    mail at aucklandcabinets dot co dot nz
  5. #25
    Service SCM BR Guest
    Thankyou auckcabs for your answer.
    For Antonio and others
    The Xilog(3, plus, maestro) only Run in PC(Windows).
    Tria Run in plataform unix developer for Esa-Gv.
    Via iPhone of the Tapatalk
  6. #26
    https://mega.co.nz/#!lspwzSYS!UPwuV3...u79Nxn8gBch20Q
    Link for download of the Xilog Plus.
  7. #27
    Jun 2015
    Hola Amigo
    muchisimas gracias por el link de descarga, pero no funciona le doy al setup para instalar y no instala
    muchas gracias amigo
  8. #28
    What the operation System? 32bits?
  9. #29
    Hi, it is solved?
    Enviado do meu iPhone usando Tapatalk
  10. #30
    Jan 2017
    24
    Quote Originally Posted by Service SCM BR View Post
    Hi, it is solved?
    I have the software on my machine, but not the manuals, do you have a copy you can link me to? I am running Xilog3 on a Record 120 built in 2000
  11. #31
    Dec 2017
    Re: Where can I find Xilog3 software?
    hi, i have scm recorder 240 an i need a software for this cnc. my plane produce cabinets an mdf doors for them.
  12. #32
    Dec 2017
    i also have morbideli a 213 need tcl file! can u someone help! code is al 1639
  13. #33
    Jun 2020
    I have same problm.
  14. #34
    Oct 2020
    Can i use xilog to program old SCM Unitech KLETRA 400?
  15. #35
    Jan 2017
    5
    hello Service SCM BR.. we have also problems loading plc and par files to the scm tech 99 we dont have the backup disk.. were can we find this information and how we load in to the machine .. thanks
  16. #36
    Apr 2018
    4
    xiloog 3 xilog plus requested !?!!!
  17. #37
    Feb 2021
    Colleagues,
    I have a MORBIDELLI m100 cnc machine.
    We use the old version of the licensed XILOG MAESTRO-EDITOR with a USB key for it from 2010.
    I need the following, if anyone can help me:
    - Does anyone have UPDATE or a newer version of "XILOG MAESTRO-EDITOR" to send me, and can work with my USB key for him?
    - I saw that MAESTRO has some limitations, so I started practicing work on ALPHACAM, so I need an explanation on how to EXPORT to a PGM or PGMX file, is there any post processor for MORBIDELLI m100?
    Any help would be welcome, I saw on the internet similar questions were asked by other MAESTRO program users. So let's help me and the others ...
    Thanks in advance!
  18. #38
    Mar 2022
    Newbie!
    Where I can find SCM Maestro for training.
    Wood Working Industry.
    Thanks a lot guys
  19. #39
    If you have an SCM machine, SCM should be able to send you a link to a demo version they have.
  20. #40
    Oct 2022
    11
    Hi, am from toronto, canada and am currently using xilog maestro programming for cnc. Has anyone used this software and where i can learn more about it and/or have taken courses on this software. Thank you ! my email is [email protected]
Page 2 of 3 123
  1. RS232 no CNC connection with Xilog software.
    By julioykaly in forum CNC Machining Centers
    Last Post: 01-04-2015, 03:52 AM
  2. Configuring a new computer to run CAM software (Xilog), couple of questions
    By StreetSpirit in forum Uncategorised CAM Discussion
    Last Post: 08-21-2013, 09:32 PM
  3. Where to find Mastercam x5 or x6 software?
    By kevindflowers23 in forum Mastercam
    Last Post: 09-17-2012, 05:45 AM
  4. 2D to 3D software. Where can I find it?
    By jaru-eri in forum Uncategorised CAM Discussion
    Last Post: 04-10-2009, 07:24 PM
  5. The most useful software that I cant find!
    By berin in forum Uncategorised CAM Discussion
    Last Post: 12-10-2004, 06:38 PM
