I would like a Haimer but can not afford one so decided to make something that will give an easy edge find for not much money nor effort.
This is a pretty simple build.
I went to the hardware store and picked up an electrical block for $6 and some aligator clips.
I already had a digital multi meter with continuity.
I solder some speaker wire to the brass electical block and honed it so all surfaces were square.
Then I applied some masting tape to one side.
The brass bock was 9.45mm and the masting tape was .1mm so all up the block was 9.55mm.
Ji
