585,931 active members*
5,662 visitors online*
    Apr 2013
    4
    floating head
    Hi all, i have a slight problem with my cnc machine. I am not sure if the problem is with sheetcam or mach3. When the floating head touches down and activates the switch the floating head stops, like it should, but then the gantry will move in the x/y axis slightly before lifting up. since this happens the cuts don't finish by about quarter inch or so. Any information would be appreciated. So if its cutting a circle the floating head will touch down, move in the x/y cut path direction , z will go back up to specified offset, then start cutting, when the cut comes back around it stops where floating head touched down originally and not where it moves to before going back up, thus not completely cutting out the part.
    -Cody
    here is the g code as well.
    N0110 G31 Z -100 F19.685
    N0120 G92 Z-0.3200
    N0130 G00 X0.0572 Y5.8088
    N0140 Z0.0000
    N0150 M03
    Im new to this whole thing but to me seems like i have an offset set somewhere in Sheetcam but not sure where?
    Oct 2010
    156
    Did you get this taken care of? What post processor were you using?
  1. Floating Z Head
    By tulsaturbo in forum Mach Plasma / Laser
    Last Post: 03-18-2021, 11:55 PM
  2. floating z head
    By BuiltByBrooks in forum Waterjet General Topics
    Last Post: 11-12-2010, 01:15 AM
  3. Floating Head Improvements?
    By Normsthename in forum Waterjet General Topics
    Last Post: 05-27-2010, 01:12 AM
  4. Z Floating Head Question(s)
    By needonemoretool in forum Waterjet General Topics
    Last Post: 03-29-2010, 05:40 PM
  5. Floating head switch
    By millman52 in forum Waterjet General Topics
    Last Post: 06-15-2009, 02:17 AM
