585,996 active members*
4,544 visitors online*
    Dec 2012
    19
    Good cnc router
    Please have a check our cnc router, it is a good machine
    Model
    FTM-1325 cnc cutting machine With ATC
    Size of worktable 1300*2500mm or others
    Spindle Motor 9.0kW Italian HSD brand spindle motor with ISO30 ATC
    Z Max feed-in 220mm
    Dring System Japanese Yaskawa servo motor and driving system
    Rack and pinion Imported helical rack and pinion for X and Y axis transimission
    Ball Screw German ball-screw for Z axis transimission
    Cutter ∮6 ∮12.7
    Power AC380V/50~60HZ
    Inverter Taiwan Delta
    Cable Wire U.S.A LTK brand
    Weight 3.1T
    Control System LNC/SYNTEC CONTROL SYSTEM
    Table Vacuum Absorption table (Aluminum table for optional)
    Pump 7.5kw Air cooling pump
    Applicable areas:
    Wood Stone working :wood.wood Solid wave board process, door of cabinet、wooden door、artistic wooden door 、avoid wind、process of the artistic window,shoes cleaning machine,the cabinet of the playing machine and the board,Granite, Marble, Bluestone, Sandstone etc
    Advertising; plastic。Advertising board、Label design、plastic / glass Acrylic cutting、model、of the multy material decoration products.Granite, Marble, Bluestone, Sandstone and other stone engraving etc
    Model industry; It can engrave on the steal materials such as copper, aluminum ,iron etc and non-mental materials such as man-made marble, sand, plastic board PVC materials, wood board etc.
    Dec 2012
    19
    Maybe I can show some videos
  1. Victor CNC Router - Is it any good at all?
    By TurkishDelight in forum Chinese Machines
    Last Post: 05-31-2012, 02:51 AM
  2. This Router Is Working Good
    By gualalasmooth in forum CNC Wood Router Project Log
    Last Post: 12-31-2011, 09:54 PM
  3. Want to buy a good CNC Router Plan
    By ryanvu in forum Want To Buy...Need help!
    Last Post: 02-12-2011, 06:32 AM
  4. EZ-Router, so far so good.
    By marksolberg in forum Commercial CNC Wood Routers
    Last Post: 07-07-2009, 03:53 PM
  5. All Aluminum Router- so far so good
    By micsit1 in forum DIY CNC Router Table Machines
    Last Post: 02-12-2009, 10:11 AM
