585,717 active members*
3,770 visitors online*
IndustryArena Forum > CNC Electronics > Rutex Products > Servo Drives > KUKA Servo Motor Control ?
Results 1 to 7 of 7
    Sep 2011
    38
    Hello Guy's
    I got 3 1.4kw servo motor's for free 2day. They are Kuka branded. My problem is, i need to know what controller will work with them that has a reasonabl price tag.
    Gecko / Chinese servo drivers...etc. They look kinda old but in good shape.
    Servo Details tag :
    KUKA Schweibanlagen + Roboter
    Gmbh D-8900 Augsburg
    AC- Servomotor 1 FT3071
    Nr E: 9k80 6063 14 014
    1.41kw 84v 11 A 3k rpm
    I.CL. F IMB14 IP64 A.Nr : 0269225445
    Hope someone can help me out.
    Thx in Advance.
    If you can Read, You can learn...If you can Learn you can do anything you set your mind to.
    24220
    I got hold of some older European origin motors and had to end up doing some reverse engineering, the first thing and most obvious is the motor technology, DC brushed? BLDC or AC sinusoidal? stepper etc?
    Al.
    Albert E.
    Sep 2011
    38
    Hey there
    Thanx for the reply. They are Ac servo motors. the one side has 11 poles and the other side has 9 poles. will take a picture of them and post aswell. thank you for your help.
ID:	185136Click image for larger version.
ID:	185138Click image for larger version.
    24220
    If they are AC servo's then they most likely have resolvers for position and commutation, if used in robotics application then they could be using absolute encoders?
    It may need further examination by removing the rear cover etc.
    Al.
    Albert E.
    Sep 2011
    38
    Hello Al
    Iv'e taken of the cover and has 2 wheels "timming ?) connected via a gear too the shaft. Ill try to get a photo up today.
    Thx
    Frans
    24220
    Sounds like it might be a resolver geared off the shaft, as was often done on this age of motor.
    A photo would confirm.
    Al.
    Albert E.
    May 2010
    Hello Guy's,
    we have similar project - for control KUKA with our servo drives - AMK Drives and Controlers!
    So I have this done with AMK servo drives. KUKA motor encoders are Resolvers but not normal resolvers!
    If you are interested and you need such kind of control please send me an e-mail
    [email protected]
    AMK Bulgaria, Application Department
  1. Need help with servo motor control.
    By yrralguthrie in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-20-2012, 03:05 AM
  2. Cards Support Stepper Motor Driver Control & AC Servo Control.
    By Johnnyatcnc in forum News Announcements
    Last Post: 04-09-2010, 09:57 AM
  3. ELM Servo Motor Control
    By gvertiz in forum CNC Machine Related Electronics
    Last Post: 02-19-2008, 09:52 PM
  4. Servo motor control...
    By WilliamD in forum CNC Machine Related Electronics
    Last Post: 08-21-2007, 04:03 AM
  5. servo motor control
    By joe plasma in forum CNC Machine Related Electronics
    Last Post: 05-17-2006, 02:34 PM
