585,573 active members*
3,516 visitors online*
    May 2013
    Emco Compact 5 Retrofit
    I have been doing a retrofit for my school on their broken compact 5. My current issue is finding a way to power and control the stock spindle motor. Any suggestions on how to control the spindle and what electronics i need. The stepper driver is a gecko g540 and I am using mach3. Also does anyone know how to do the macro for the tool turret?
    Here is a pic of the machine currently.
    Attachment 185098
    Dec 2009
    I rebuilt my machine, Daniel, about 12months ago. I used a DC power drive from Parker drives, here in the UK. This takes the spindle on/off signal from your breakout board and also a 0-10v speed control signal. Works well. I have developed a macro for the tool turret, if you want it.
    Best Wishes
    Rob.
    Re: Emco Compact 5 Retrofit
    So.. Parker makes DC Drives for these spindle motors?.. Nice.. it might be something for my lil' EMCO..
    http://www.cnczone.com/forums/vertic...ml#post1627250
    i'm not Using Mach3 Though.. i use EdingCNC instead..
    i've found that the Emco 5 Compact CNC is very accurate.. at the moment i'm producing Titanium watchcases.. 2 weeks ago i made the casebacks.. tolerances of 0.01mm.. i only had to adjust the diameter twice in a series of 52 parts.. all done with only one tool.. ain't that something?
  1. emco compact 5
    By h_2_o in forum Mini Lathe
    Last Post: 01-14-2015, 12:56 AM
  2. EMCO COmpact 6
    By mikeDK in forum EMCO Lathe
    Last Post: 09-09-2014, 10:09 AM
  3. Emco Compact 6, HELP PLEASE
    By wahab_002 in forum EMCO Lathe
    Last Post: 03-15-2010, 09:20 PM
  4. Emco Compact 6
    By SASMAN in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2009, 09:27 AM
  5. EMCO compact 5 PC to win XP?
    By SBruceSmith in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-29-2006, 08:30 PM
