585,996 active members*
4,725 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Surfcam 6 Patch 2
Results 1 to 7 of 7
    Feb 2012
    125
    Surfcam 6 Patch 2
    It´s available a new patch
    *************************SURFCAM 6 B136 Patch 2********************************
    SC-29xxx: Display Lockups in Surfcam
    SC-29xxx: Solidworks sketches cannot be imported if only SW2013 is installed
    SC-29126: License warning not issued before expiration
    SC-29057: Splash Screen for Demo MOde is missing
    SC-29073: Cancel on New3Axis HSM operations freezes SUrfcam
    SC-29033: Creating rectangle with arc crashes Surfcam
    SC-29107: File save error in 64 bit due to corrupt entities
    Sc-29143: Upon Posting from MPost, users get a warning overwrite template
    Apr 2003
    637
    A perfect example of too little too late. This program is a mess with no hope in sight. Why does the build still stay B136 after this patch? I’m sure glad we’re not wasting money on maintenance anymore.
    Jan 2012
    97
    It still crashes about the same amount, but now, if you forget to plug in your Key, it displays the "Demo Screen". Which is kind of nice....;-) BTW, that new "Demo Screen" pop up, is really the only way to know that you've upgraded to Patch 2....
    Jan 2009
    To check to see if Patch2 is installed do the following:
    R-click on Surfcam Desktop Icon
    L-click on "Properties"
    Under "Shortcut" tab, L-click on "Open File Location"
    Use scrollbar to look for file named "patch.txt"
    Double-click on the file...it should open with Notepad or whatever application is associated with .txt files.
    The top line should look something like this:
    If you do not see Patch 2 in that line, Patch 2 is NOT installed.
    Apr 2003
    637
    If note pad is your default .txt editor make sure that it opens wide enough to read that top line or it will not show everything.
    I’m seeing more crashes/ lockups since I loaded this patch also. Two today. Before I could hit ok when I got a access error and continue, now it locks up with a GP fault. Figures…
    Feb 2012
    125
    So far 0 failures. But I notice it is slower to do operations such as select all.
    The patch.txt is located in surfcam directory
    x64 - C:\Program Files\SURFCAM\SURFCAM6
    x86 - C:\Program Files (86)\SURFCAM\SURFCAM6
    Jan 2012
    97
    Angry
    I had a tool path with 8 tools, just about finished... SUDDENLY.... Boom, I forgot to do incremental saves and now, its gone....
    Sitting here madder than a wet Cat...
    For me it crashes just as often as it did before I patched it up. The ONLY difference that I have noticed is that "Demo Version" comes up if the official SIM is not plugged in...
  1. Super X1 Y axis noisey in one patch
    By bruce_miranda in forum Benchtop Machines
    Last Post: 10-12-2008, 11:38 PM
  2. Stock size? new patch
    By mikeh78 in forum BobCad-Cam
    Last Post: 08-22-2008, 08:07 PM
  3. New V22 Patch on the way
    By CNCdude in forum BobCad-Cam
    Last Post: 08-14-2008, 03:25 AM
  4. Need a patch for Ez-cam for Lathe
    By Exodus8931 in forum Uncategorised CAM Discussion
    Last Post: 07-08-2008, 05:57 PM
  5. Bobcad has a new patch released
    By HuFlungDung in forum BobCad-Cam
    Last Post: 06-10-2003, 05:04 PM
