is there a way to upload all programs from machine to memory card it has 18 It controls
If it has a PCMCIA slot next to the LCD, you should be able to set the I/O Device to 4 to input/output to the card. You'll need a PCMCIA-CF adapter and a CF card. I've had the best luck with old-style SanDisk cards, i.e.:
PCMCIA Laptop Compact Flash Adapter -
SanDisk 256MB Compact Flash CF Memory Card -
The procedure is in the Fanuc manal. If you can't find it, yell.
i should have been a little more clear with the question. i have about 90 programs in the machine and i would like to dump them all at the same time onto a card. if i have to do them one at a time it will take to long
I believe you can specify a range of programs to output, such as "O0001, O2001" will output all the programs from O0001 to O2001 inclusive, or -9999 will output all programs into one large file on the card. You can then manually separate this file into single programs in a text editor.
Ok!!! Thanks I will give a try on Monday ..
This information is from the 18i pocket guide: (it is a copy and paste, so formatting did not follow. I can send the full PDF if requested)
19.1.2.6 Outputting part program
1. Confirm the following parameters. If this parameter is set to 1, rather
than the value indicated by , change to MDI mode and then reset to
0.
However, if you changed the parameter setting, restore the original value
after finishing this work.
#7 #6 #5 #4 #3 #2 #1 #0
3202 NE9 NE8
#0 (NE8) 0 :Programs of 8000s are edited.
1 :Programs of 8000s can be protected.
#4 (NE9) 0 :Programs of 9000s are edited.
1 :Programs of 9000s can be protected.
3204 P9E P8E
P8E Editing of subprograms 80000000 to 89999999 is:
0 :Not inhibited
1 :Inhibited
NOTE This parameter is valid when the program number O 8–digit option
is selected.
P9E Editing of subprograms 90000000 to 99999999 are:
0 :Not inhibited
1 :Inhibited
The following editing types become impossible.
is selected.
2. Select EDIT mode.
3. Press PROG key and press soft key [PRGRM] to display program text.
4. Press [(OPRT)] key and press soft key .
5. Input a program number to be output. To output all programs input as:
O – 9 9 9 9
6. Press [PUNCH] and [EXEC] key, then program output is started.
Doosan Service Technician
[email protected] O:973-618-2461 M:973-803-9479
