585,573 active members*
3,516 visitors online*
Results 1 to 9 of 9
    May 2013
    Mitsubishi Meldas 64 - out of memory
    I have managed to send program to Meldas 64 using rs232-usb device.
    However, I have discovered that there are only 17500 characters in memory for the program. Only 17 kB! Even smallest of my programs is bigger than this.
    So my question:
    1. Is this the right amount of memory for Meldas 64, or did something broke, or something is misconfigured?
    2. Can I expand the memory? Buy some memory module?
    Meanwhile I tried to perform drip feed, but with no luck - most programs seem to ignore XON/XOFF (or machine does not send it?). One program (CNC File Transfer) managed to detect machine buffer overflow, and send some data only after few instructions were processed, but some block were missing.
    Jan 2011
    350
    Well one thing I know for sure is that that you are supposed to have waaay more memory than that, don't know if your memory is just broken but I don't think there are params for memory size so that's unlikely to be configuration.
    May 2013
    That's sad information.
    I have taken a look at the internal circuits but I cannot locate anything that resemble a memory module (in order to fetch and replace the part).
    Jan 2011
    350
    You know what? You have everything backed up? Maybe that formatting memory would do the trick (maybe your memory's corruption may be corrected by formatting).
    Here are the instruction manual for backing up data on Magic 64, gimme your email if you want me to send you the doc. Make sure you know the procedures to load everything back in your control, I don't have that particular document, you may ask meau for one.
    Edit: Just noticed that this document shows F2 for restore. Should do the trick. Cheers.
    MELDAS
    Magic 64 Control Backup
    USA-E99081-230*
    MITSUBISHI ELECTRIC AUTOMATION
    USA
    List of Revisions
    Rev
    Date of Revision
    Detail
    Author
    3/30/11
    First edition
    TSS
    M60
    Magic64
    Backing up Magic control.
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 1 of 3
    Purpose:
    Save data through either the Floppy Drive or Hard Drive.
    Overview:
    This procedure will help to keep data updated for Magic control.
    Tools Needed:
    Floppy Disk (optional)
    Keyboard (optional)
    Instructions:
    I. . Backing up Control
    A. Backing up to Hard Drive
    1. Press the SF16 key (IN/OUT).
    2. Press the F1 key (BACKUP).
    3. Press the "H" Key for Hard Drive.
    4. Press the "S" key and type in the name of the subdirectory you would like to create. (Name of subdirectory cannot be longer than 8 characters). Files will be stored on the Hard Drive under C:\NCBAK\
    5. Press Enter.
    6. Press Enter again. The M01 side should begin to highlight yellow, wait until it completes backing up the control.
    M60
    Magic64
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 2 of 3
    7. You will get a message "The backup operation has been completed".
    8. Press Enter or click Ok.
    B. Backing up to Floppy Disk
    1. Insert Floppy Disk.
    2. Press the SF16 key (IN/OUT).
    3. Press the F1 key (BACKUP).
    4. Press the "F" key for the floppy drive.
    5. Press the "S" key and type in the name of the subdirectory you would like to create. (Name of subdirectory cannot be longer then 8 characters).
    6. Press Enter.
    7. Press Enter again. The M01 side should begin to highlight yellow, wait until it completes backing up the control.
    M60
    Magic64
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 3 of 3
    8. You will get a message "The backup operation has been completed".
    9. Press Enter or click Ok.
    May 2013
    Thank you for instruction.
    However, how can I do this backup? My Meldas don't have keybord, hard drive, nor floppy drive.
    But more important question: how to format the memory?
    Jan 2011
    350
    I'm not sure what control you have if it's not M64... is it a 60 or 600 series control?
    I have explanations for 50 and 500 controls, I think it's pretty similar. As I told you PM me your email if you want the docs with all the pictures on it.
    Cheers.
    50 control:
    MELDAS
    M50 Backup and Restore via RS232
    USA-E99071-022*
    USA
    List of Revisions
    Rev
    Date of Revision
    Detail
    Author
    7/20/09
    First Edition
    TSS
    M50 Series
    RS-232 Communication Procedure using Procomm4.8
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 1 of 5
    Purpose:
    The purpose for this procedure is to make a backup for your machine just in case you lose memory caused by a power outage or you are replacing a part that contains memory.
    Overview:
    This procedure will instruct you on how to back up and reload all the entire data on a step by step basis.
    Tools Needed:
    RS-232 communication cable
    Procomm Plus 4.8
    Instructions:
    I. Set-up the RS-232 communication cable.
    A. Verify the RS-232 Cable configuration.
    B. Connect the RS-232 Cable.
    II. Verify Procomm settings on personal computer.
    A. Open Procomm Plus 4.8, on the personal computer.
    B. Verify the ‘Quick Select Line’ on the Procomm Plus Window
    1. Click on View and check ‘Quick Select Line’
    2. The ‘Quick Select Line’ is displayed on the bottom of the Procomm Window.
    3. The ‘Quick Select Line’ should display VT-100, ASCII, direct connect-COM1, 9600, E72.
    III. Set-up the M50 series I/O parameters.
    A. Access the I/O Parameters.
    1. Press [TOOL/PARAM] hard key.
    2. Press [MENU] soft key one time.
    3. Press [I/O PAR]. (You will see [I/O BASE PARAM] page (1/6).)
    B. Set “DATA IN” FOR Port 1(CH1) and Device 0 from I/O Parameters.
    1. Press [9001], [>] cursor, [1] then Input. (This sets the port to 1.) #(9001)DATA(1)
    2. Press [9002], [>] cursor, [0] then Input. (This sets the device to 0.)
    #(9002)DATA(0)
    C. Set ‘DATA OUT’ for Port 1 (CH1) and Device 0; from the I/O Parameters
    1. Press [9003], [>] cursor, [1] then Input. (This sets the port to 1.) #(9003)DATA(1)
    2. Press [9004], [>] cursor, [0] then Input. (This sets the device to 0.) #(9004)DATA(0)
    3. You should see the following:
    C. Set the Device 0 Parameters from the I/O Parameters.
    1. Press [>] Page Key.
    <I/O> #<Port> #<Device> #<Dev. Name>
    Data In 9001 1 9002 0
    Data Out 9003 1 9004 0
    M50 Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 2 of 5
    2. Set parameter according to the following:
    D. Turn off Edit Lock B.
    1. Select [TOOL/PARAM] hard key.
    2. Select [MENU].
    3. Select [PROCESS].
    4. Press [>] to page over to 2/4.
    5. Type #(8105)Data(0). Press Input.
    E. Turn off Edit Lock C.
    2. Press [MENU] soft key.
    3. Press [SETUP] soft key.
    4. Press [Y].
    5. Press Input.
    6. Press [BASE] menu key.
    7. Press [>] to page 5/8.
    8. Type #(1121)Data(0). Press Input.
    IV. Download data from NC (Programs, Tool Data, Parameters and Maintenance)
    A. Access the Data Output screen
    1. Press [DIAGN/IN/OUT] hard key.
    2. Press [MENU] soft key 2 times.
    3. Press [OUTPUT] menu key.
    # =====Dev. 0=====
    9101 Device Name RS2 9111 DC2/DC4 Output 0 9121 EIA Code [ 00
    9102 Baud Rate 1 9112 CR Output 1 9122 ] 00
    9103 Stop Bit 3 9113 EIA Output 0 9123 # 00
    9104 Parity Check 0 9114 Feed Chr. 200 9124 * 00
    9105 Even Parity 0 9115 Parity V 0 9125 = 00
    9106 Chr. Length 3 9116 Time-out (sec.) 30 9126 : 00
    9107Terminator Type 0 9117 DR Off 0 9127 $ 00
    9108 Handshake 3 9118 Data ASCII 0 9128 ! 00
    9109 DC Code Parity 1 9119 9129
    9110 91209130
    M50 Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 3 of 5
    B. Set up PC to receive data and give it a file name.
    C. Send file from CNC to PC:
    1. For Programs, type:
    #(1)Data(ALL) then press Input
    2. For Tool Data, type:
    #(2)Data(ALL) then press Input
    3. For Parameters, type:
    #(3)Data( ) then press Input
    4. For Common Variables, type
    #(5)Data( ) then press Input
    5. For Macro Programs, type
    #(30)Data( ) then press Input
    Note: You should see the data on the screen being outputted; when it is done the screen will show “DATA OUT COMPLETE”
    D. Stop the Ladder and Output the Maintenance files.(See appendix for explanation of maintenance files)
    1. Press Emergency Stop.
    2. Turn CS2 on the control to 1 to stop the ladder.
    3. Set up PC to receive data and give it a file name.
    4. Select one of the following:
    For ALL1, Type:
    #(99)Data(ALL1) then press Input For ALL2, Type:
    #(99)Data(ALL2) then press Input For ALL3, Type:
    #(99)Data(ALL3) then press Input
    5. Turn CS2 on the control to 0 to start the ladder.
    VII. Upload data to the NC (Programs, Tool Data, Parameters or Maintenance).
    A. Access the Data Input screen.
    3. Press [INPUT].
    M50 Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 4 of 5
    B. Set up CNC to receive file. (The CNC must be ready to receive file before sending from PC)
    1. For Parameters, type (CNC will need to be formatted after loading Parameter file. See M50 Format Memory Procedure)
    #(3)Data( ) then press Input.
    1. Power Off/On.
    #(2)Data( ) then press Input
    3. For Programs, type:
    #(1)Data( ) then press Input
    C. Send file from PC to CNC
    Note: You should see the data on the screen being outputted; when it is done the screen will show “DATA IN COMPLETE”
    D. Upload Maintenance Files.
    Note: You must first stop the PLC. Otherwise you will get error ‘E24 PLC RUN’.
    3. Set up CNC to receive data (The CNC must be ready to receive file before sending from PC)
    For ALL1, Type:
    #(99)Data( ) then press Input For ALL2, Type:
    #(99)Data( ) then press Input For ALL3, Type:
    6. Release the Emergency Stop.
    7. Cycle power on machine
    M50 Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 5 of 5
    500 control:
    MELDAS Series
    RS-232 Procedure for M520A
    USA-
    E99061
    -060*
    USA
    List of Revisions
    Rev
    Date of Revision
    Detail
    Author
    06/2/04
    First Edition Created
    TSS
    M520A Series
    - M520AL and M520AM -
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 1 of 10
    Set-up:
    1) Set-up the RS-232 communication cable and Procomm Setting on personal computer
    a. Verify the RS-232 Cable configuration.
    b. Verify Procomm Settings.
    2) Connect the RS-232 cable and open Procomm Plus 4.8
    a. Connect the RS-232 Cable;
    i. Plug the DB9 connector to the RS-232 port on the Personal Computer.
    ii. Plug the DB25 connector to the RS-232 port on to the port on the machine panel.
    The DB25 should be connected to CH1 of the SA21-1 or -2 cables on the QX522.
    ** SA21-1 and SA21-2 Cable Diagrams are listed on the last pages.
    b. Open Procomm Plus 4.8
    On the personal computer
    i. Click on the Start, Programs, Procomm Plus, Procomm Plus
    c. Verify the ‘Quick Select Line’ on the Procomm Plus Window
    i. Click on View and check ‘Quick Select Line’
    4
    5
    6
    8
    7
    20
    7
    8
    4
    6
    5
    (RD)
    (SD)
    (RTS)
    (CTS)
    (DCD)
    (DTR)
    (DSR)
    (SG)
    (TD)
    (SD)
    (RTS)
    (SG)
    (CTS)
    (DSR)
    (DCD)
    (DTR)
    M520A Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 2 of 10
    3) Set-up the M520 series I/O parameters
    a. Access the I/O Parameters;
    i. Press the [DIAGN IN/OUT] Function Select Key
    ii. Press the [MENU] Menu Key two times
    iii. Press the [PARAM] Menu Key
    You should see [I/O BASE PARAM] on the upper-left and page (1/5) on the upper-right of the NC screen.
    b. Set DATA IN for Port 1 (CH1) and Device 0;
    On the [I/O BASE PARAM] page (1/5)
    i. Press [01], [>]cursor, [1] then [INPUT], Set the port
    ii. Press [0] then [INPUT], Set the device
    c. Set DATA OUT for Port 1 (CH1) and Device 0;
    i. Press [03], [>]cursor, [1] then [INPUT], Set the port,
    ii. Press [0] then [INPUT], Set the device,
    # <PORT> <DEVICE>
    1 DATA IN 1 0 : MEA
    2 DATA OUT 1 0 : MEA
    d. Set the Device 0 Parameters;
    First Access the I/O Parameters then press [>] Page Key.
    On the [I/O DEVICE PARAM (1)] page (2/5)
    i. Press [0], [>] cursor, [1], [>] cursor, [MEA] then [INPUT], Set the Device Name,
    ii. Press [1] then [INPUT], Set the Baud Rate to 9600BPS;
    iii. Press [3] then [INPUT], Set the Stop Bit to 2;
    iv. Press [0] then [INPUT], Set the Parity Effective to ‘not added’;
    v. Press [0] then [INPUT], Set the Even Parity to ‘Even’;
    vi. Press [3] then [INPUT], Set the Character Length to 8-bits;
    vii. Press [0] then [INPUT], Set the Term. Type ‘at the EOR code’;
    viii. Press [0] then [INPUT], Set the Code 1;
    ix. Press [0] then [INPUT], Set the Code 2;
    x. Press [0] then [INPUT], Set the Rewind Code;
    xi. Press [3] then [INPUT], Set the Handshake to ‘DC’ code;
    xii. Press [1] then [INPUT], Set the DC Code Parity to ‘no parity’;
    xiii. Press [>] Page Key, Access page (3/5);
    On the [I/O DEVICE PARAM (2)] page (3/5)
    xiv. Press [0], [>] cursor, [1], [>], [0] then [INPUT], Set the DC2/DC4 Output to ‘none’;
    xv. Press [1] then [INPUT], Set the CR Output to ‘add’;
    xvi. Press [0] then [INPUT], Set the EIA Output to ‘ISO’;
    xvii. Press [0] then [INPUT], Set the Title Feed Out to ‘200’;
    xviii. Press [0] then [INPUT], Set the Parity V to ‘Do not check’;
    xix. Press [90] then [INPUT], Set the Time Out to 90 seconds;
    xx. Press [0] then [INPUT], Set the RST Ignore to ‘valid’;
    M520A Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 3 of 10
    Disable Edit Locks:
    1) Verify that the edit switch on the operation panel is set to OFF
    2) Verify and set the Edit Lock B Parameter on the Process Parameter Screen
    a. Access page (2/2) the Control Parameter;
    i. Press the [TOOL/PARAM] Function Select Key
    iii. Press the [CONTROL] Menu Key
    iv. Press the [>] Page Key
    You should see [CONTROL PARAMETER] on the upper left and page (2/2) on the upper right of the NC screen.
    b. Verify and remove highlight of #40 EDIT LOCK B parameter;
    First access page (2/2) of the Control Parameter.
    i. View and verify if parameter #40 is highlighted.
    ** You will need to set this back to the original setting when completed.
    * If #40 EDIT LOCK B is highlighted then perform then
    ii. Press [40], then [INPUT], Set the #40 to ‘edit’;
    * If #40 EDIT LOCK B is not highlighted then move to next step
    (Verify and set Edit Lock C Parameter in the Machine Parameters)
    3) Verify and set the Edit Lock C Parameters on the Machine Parameter Screen
    a. Access the Machine Parameter Screen;
    ii. Press the [PLC-I/F] Menu Key
    iii. Press the [1001], [>]cursor two times, [M], then [INPUT]
    iv. Press the [TOOL PARAM] Menu Key
    You should see [BASE SPEC. PARAM] on the upper left and page (1/10) on the upper right of the NC screen.
    b. Verify and change the #7 edlk_c parameter;
    First access the Machine Parameter then press [>] Page Key four times to page (5/10).
    i. View and write down the current value of #7
    * You will need to set this back to the original value when completed.
    ii. Press [7], [>] cursor, [0] then [INPUT], Set the #7 to ‘Edit’;
    M520A Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 4 of 10
    Output and Input of User Data
    1) Output of User Data - Programs, Tool Data, Common Variables and Macro Programs
    a. Access the DATA OUTPUT screen
    i. Press the [DIAGN IN/OUT] Function Select Key,
    ii. Press the [MENU] Menu Key,
    iii. Press the [OUTPUT] Menu Key
    You should see [DATA OUTPUT] on the upper left-side of the screen.
    b. Output all Programs
    First Access the DATA OUTPUT screen on the M520A control
    On the personal computer, Set-up Procomm to send a file
    i. Press Ctrl+Alt+4 on the personal computer (make sure the Procomm Window is active)
    ii. Type in a file name such as M520APrograms (it should save it as a .txt file)
    iii. Click Save
    On the M520A, DATA OUTPUT screen;
    iv. Press [1], [>] cursor, [ALL], then [Input], Output all Programs;
    c. Output a single Program (For example program number 123)
    ii. Type in a file name such as Program123 (it should save it as a .txt file)
    iii. Click Save
    iv. Press [1], [>] cursor, [123], then [Input], Output programs number 123;
    d. Output a range of program (For example programs between 123 through 789)
    On the personal computer, Set-up Procomm to send a file (make sure the Procomm Window is active)
    ii. Type in a file name such as M520APrograms2 (it should save it as a .txt file)
    iii. Click Save
    iv. Press [1], [>] cursor, [123], [>] cursor,[789] then [Input], Output programs number 123 through 789;
    e. Output all Tool Data
    ii. Type in a file name such as M520ATools (it should save it as a .txt file)
    iii. Click Save
    iv. Press [2], [>] cursor, [ALL], then [Input], Output tool data;
    f. Output all Common Variables
    ii. Type in a file name such as M520AVariables (it should save it as a .txt file)
    iii. Click Save
    iv. Press [5], [>] cursor, [ALL], then [Input], Output the common variables;
    g. Output all Macro Programs
    M520A Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 5 of 10
    ii. Type in a file name such as M520AMacros (it should save it as a .txt file)
    iii. Click Save
    iv. Press [30], [>] cursor, [ALL], then [Input], Output the macro programs;
    2) Input of User Data - Programs, Tool Data, Common Variables and Macro Programs
    a. Access the DATA INPUT screen
    ii. Press the [MENU] Menu Key, then [MENU] Menu Key
    iii. Press the [INPUT] Menu Key
    You should see [DATA INPUT] on the upper left-side of the screen.
    b. Input all Programs
    First Access the DATA INPUT screen on the M520A control
    On the M520A, DATA INPUT screen;
    i. Press [1], [>] cursor, then [Input], Input all Programs;
    ii. Press Ctrl+Alt+3 on the personal computer
    iii. Choose the file such as M520APrograms (saved earlier as a .txt file)
    iv. Click Open
    c. Input a single Program (For example program number 123)
    i. Press [1], [>] cursor, then [Input], Input a single program;
    iii. Choose the file such as Program123 (saved earlier as a .txt file)
    iv. Click Open
    d. Input all Tool Data
    i. Press [2], [>] cursor, then [Input], Input all Tools;
    iii. Choose the file such as M520ATools (saved earlier as a .txt file)
    iv. Click Open
    e. Input all Common Variables
    i. Press [5], [>] cursor, then [Input], Input all Common Variables;
    iii. Choose the file such as M520AVariables (saved earlier as a .txt file)
    iv. Click Open
    f. Input all Macro Programs
    i. Press [30], [>] cursor, then [Input], Input all Macro Programs;
    iii. Choose the file such as M520AMacros (saved earlier as a .txt file)
    iv. Click Open
    M520A Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 6 of 10
    Stop PLC, Output and Input Maintenance Information
    1) Stop the PLC to backup Maintenance Data
    a. Prepare the machine
    i. Command each axis to machine zero
    ii. Press [RESET]
    iii. Press the Emergency Stop Button
    b. Access the Bit Select Screen
    iii. Press [PLC]
    iv. Press [>] Page Key eight times to page (9/10)
    You should see [BIT SELECT] on the upper left-side and page (9/10) on the upper right-side of the NC screen.
    c. Enable the PLC On-board Function
    First Access the Bit Select screen.
    View and write down the current value of #51 bit 0.
    ** You will need to set this back to its original value.
    i. Press [51], [>] cursor eight times, [1] (under bit-0), then [INPUT], Enable the PLC On-board function;
    d. Access the 4RUN/SP screen
    i. Press the [F0] Function Key
    iii. Press the [FILE] Menu Key
    iv. Press the [4RUN/SP] Menu Key
    e. Stop the PLC
    i. Press [1], then [INPUT], Stop the PLC;
    2) Output of Maintenance Data – Parameters, ALL1, ALL2 & ALL3
    ii. Press the [MENU] Menu Key, then <MENU> Menu Key
    b. Output all Parameters
    ii. Type in a file name such as M520AParameters (it should save it as a .txt file)
    iii. Click Save
    iv. Press [3], [>] cursor, [ALL], then [Input], Output all Parameters;
    c. Output ALL1 Maintenance Data
    ii. Type in a file name such as M520AALL1 (it should save it as a .txt file)
    iii. Click Save
    iv. Press [99], [>] cursor, [ALL1], then [Input], Output ALL1 Maintenance Data;
    M520A Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 7 of 10
    d. Output ALL2 Maintenance Data
    ii. Type in a file name such as M520AALL2 (it should save it as a .txt file)
    iii. Press Save
    iv. Press [99], [>] cursor, [ALL2], then [Input], Output ALL2 Maintenance Data;
    e. Output ALL3 Maintenance Data
    ii. Type in a file name such as M520AALL3 (it should save it as a .txt file)
    iii. Press Save
    iv. Press [99], [>] cursor, [ALL3], then [Input], Output ALL3 Maintenance Data;
    3) Input of Maintenance Data – Parameters, ALL1, ALL2 & ALL3
    b. Input all Parameters
    i. Press [3], [>] cursor, then [Input], Input all Parameters;
    iii. Choose the file such as M520AParameters (it should save it as a .txt file)
    iv. Click Save
    c. Input ALL1 Maintenance Data
    i. Press [99], [>] cursor, [ALL1], then [Input], Input ALL1 Maintenance Data;
    iii. Choose the file such as M520AALL1 (it should save it as a .txt file)
    iv. Click Save
    d. Input ALL2 Maintenance Data
    i. Press [99], [>] cursor, [ALL2], then [Input], Input ALL2 Maintenance Data;
    iii. Choose the file such as M520AALL2 (it should save it as a .txt file)
    iv. Press Save
    M520A Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 8 of 10
    e. Input ALL3 Maintenance Data
    i. Press [99], [>] cursor, [ALL3], then [Input], Input ALL3 Maintenance Data;
    iii. Choose the file such as M520AALL3 (it should save it as a .txt file)
    iv. Press Save
    4) Restart the PLC
    a. Access the Bit Select Screen
    ii. Press the [MENU] Menu Key three times
    iii. Press [PLC]
    iv. Press [>] Page Key four times to page (5/6)
    You should see [BIT SELECT] on the upper left-side and page (5/6) on the upper right-side of the NC screen.
    b. Access the 4RUN/SP screen
    c. Restart the PLC
    First access the 4RUN/SP screen
    i. Press [0], then [INPUT], Stop the PLC;
    d. Cycle Power to the Machine
    i. Power OFF the M520A control and Main Circuit Breaker
    ii. Power ON the Main Circuit Breaker and M520A control.
    M520A Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 9 of 10
    Set all changes back to original setting
    1) Set the Edit Lock B Parameter to its original setting
    a. Access the Control Parameter;
    You should see [CONTROL PARAMETER] on the upper left and page (1/4) on the upper right of the NC screen.
    b. Verify and change the #40 EDIT LOCK B parameter to its original setting
    2) Set the Edit Lock C Parameters to its original setting
    b. Verify and change the #7 edlk_c parameter to its original setting;
    3) Set the PLC On-board Bit Select to its original setting
    ii. Press the[MENU] Menu Key three times
    iii. Press [PLC]Press [>] Page Key four times to page (9/10)
    b. Verify and change #51 Bit 0 to its original setting
    M520A Series
    Mitsubishi Electric Automation Inc. - MEAU Home Mitsubishi Electric Automation, Inc. Page 10 of 10
    SA12-1, SA21-1 and SA21-2 Cable Diagrams
    May 2013
    The machine is Way Shine VEM-15 Mitsubishi Meldas 64. The button names and settings numbers for 50 control looks familiar to me.
    I've PM-ed you my email. Does manual contain format procedure as well?
    Feb 2005
    28
    Re: Mitsubishi Meldas 64 - out of memory
    Hello to All Friends
    I need your help
    I have a hartford machining center, whitch work with meldas magic64.
    I need system floppys
    Meldas magic64 nc system disk 1 and 2
    Meldas magic utility disk 1 and 2
    Meldas magic meldasmagic monitor disk 1
    Meldas magic custom API library runtime disk 1 and 2
    Meldas magic64 NC data 64m disk 1
    Please help me
    If u have these floppy's please send me a soft copy
    My email. [email protected]
    Thanks in advance
    Oct 2022
    QT-6 Mazak lost parameters
    Hello guys!
    Does any one have parameters Meldas 64? can share it
    I would appreciate it
    Thanks in advance
  1. Mitsubishi Meldas 60S
    By BKCOM in forum Mitsubishi controls
    Last Post: 11-28-2016, 03:59 PM
  2. mitsubishi meldas 64
    By billetman123 in forum Mitsubishi controls
    Last Post: 11-01-2016, 09:53 AM
  3. meldas m0 memory over label..
    By Nikola in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-01-2015, 02:24 PM
  4. Mitsubishi Meldas L2
    By Bert10 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-13-2011, 04:13 PM
  5. Running into memory issues Mitsubishi M-V60C - Meldas 300 Controller
    By Josh Lehman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-07-2009, 04:38 PM
