584,325 active members*
14,766 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > 4AXIS STRATEGIE ROTARY MODEL ( NOT WRAPPED / NOT STRAIGHT MODEL )
    Dec 2009
    Question 4AXIS STRATEGIE ROTARY MODEL ( NOT WRAPPED / NOT STRAIGHT MODEL )
    Hi every body
    i have 4 axis machine XYZA axis , (the rotary axe along x axis )
    i have a problem while doing rotary g codes with the following model style
    Attachment 185564
    i am new user with gibbscam , i need your help , which steps i must follow from A to Z
    to finally have g codes for my stl model which is not straight along one line
    Aug 2006
    123
    I think the problem is that you are using a .STL file for geometry. AFAIK you can't use .STL for surfacing in gibbs. I found that it is almost impossible to convert from .STL to anything useful for programing.
    Apr 2018
    Re: 4AXIS STRATEGIE ROTARY MODEL ( NOT WRAPPED / NOT STRAIGHT MODEL )
    not from file just mach3 cant read my g code will or i have mistake about output g code
  1. Manuals for Wasino Model LG-71 Turning Center and Mori Seiki Model MV-40B VMC
    By innovativeiron in forum Machinery Manuals / Brochures
    Last Post: 11-07-2013, 02:28 AM
  2. surface model vs Solid model machining
    By Marcutous in forum Daewoo/Doosan
    Last Post: 12-02-2012, 03:45 PM
  3. 4 axis rotary - tool clashes with model
    By prdp141 in forum Rhinocam
    Last Post: 07-15-2012, 09:35 AM
  4. How To Model Rocks for Site Model
    By limbatus in forum Rhino 3D
    Last Post: 01-17-2012, 08:39 PM
  5. Replies: 1
    Last Post: 01-01-2010, 12:50 PM
