585,557 active members*
3,395 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Cutting 2.5 and 3 inch wood?
    May 2013
    20
    I am ganna be cuttin 2.5 and 3 inch hardwood and am wandering what kind of bits ull are using to cut that thick of wood?
    Apr 2004
    5731
    Cutting it how? Are you cutting simple shapes out of it or 3d contours? You need different tools depending on what you're trying to do, but if you want to reach the bottoms of those thick pieces of wood, then you need tools that are long enough to reach there, and enough headroom to clear the workpiece.
    Andrew Werby
    www.computersculpture.com
    May 2013
    20
    It is a arched table leg without a profile. is it better to do several passes with a hogger then one pass with a finsher?
    Apr 2004
    5731
    Yes, you should set up a roughing operation that gets most of the material out of the way with successive passes of a large tool that aren't too deep, leaving a little material positive on the surface. Then, when you're close to your net shape, set up a finishing operation to put in the details or smooth the surfaces. All but the very most basic 3d CAM programs allow you to do this, but if you don't have one, download DeskProto and try it.
    Andrew Werby
    Apr 2007
    663
    Try to remove most of wood with a bandsaw. Then you might be able to just run the finish cut. Normal power and/or hand woodworking tools used in conjunction with CNC are a powerful combination. Plus it gives you an excellent excuse to have more tools!!!
  1. Where can I buy a 1/8" End Mill (cutting 4140 HT) that can cut at least 1 inch Deep?
    By Gun-Machine in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-18-2011, 02:57 PM
  2. Cutting 1 inch thick bar
    By JOHNBOY in forum Hypertherm Plasma
    Last Post: 05-17-2011, 12:39 PM
  3. 4 inch cutting discs
    By nc9933 in forum MetalWork Discussion
    Last Post: 12-21-2009, 03:55 AM
  4. Setting inch per minute cutting speed
    By Edwardo in forum DynaTorch
    Last Post: 06-03-2009, 03:21 PM
