Hi, I'm looking to build an aluminum cutting 3 Axis with a 4KW spindle (from eBay). I only have 220V single phase in my shop, and I'll be reusing a 60Amp welder plug I have on the wall.
There are some VFDs that will take 220V Single Phase OR 220V 3 Phase as inputs, but am I right in thinking I'd need to double the VFD size when using 220 Single Phase as the input?
For instance, if I had a 4kw(5HP) spindle, I'd need a 5HP VFD if I had 3 phase as the input to the VFD. Since I only have single phase input, I'd need a 10HP VFD that still allows 220V single phase input (so that it will put out 1/2 of 10HP (5HP) in 3 phase for the spindle)
In that case, can anyone recommend a 10HP VFD to use with 220V Single Phase input and 220V 3 Phase output?
Thanks for any clarification, have a nice day.
