I have a Fanuc OM-D control on a mill, until recently I was able to upload and down load programs from PC with no problems. Now for some reason I've lost that capability I've tried a new cable, and double checked with a VOM to make sure the cables were right. I know it's not a computer problem, or a software problem. The memory board where the punch panel cable connects is a A16B-2201-0101/08b this board has two ports M5 and M74, M5 is the defualt port m74 can be enabled somehow (I assume for the right price I can get the parameter to turn it on. But I was told by Fanuc service that electrically they are the same.
I use a RS 232 signal indicator from radio shack.
when hooked up to M5 port I get I get a red light on RD and green lights on three others, when hooked up to M74 I get a red light on RD a green light on TD and green lights on everything else but CSD and RSD where I get no lights. My next move is to send the whole board back to Fanuc for rrepair unless someone has some idea whats going on from this info. any help would be appreciated as this machine is not much good without the interface.
