585,605 active members*
3,251 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Revamping to GibbsCAM from SmartCAM but don't know what post file to use for VF-4?
    Feb 2013
    I just started programming for a shop where they have Gibbs and SmartCAM. I like SmartCAM for now for the big G&L HMills, but for the VF Haas VMC I would like to start using Gibbscam. I know I probably have the right post processor file on my programming computer as they purchased all the options we would ever need. I just don't know what the name of the file to search for would be. Or does anyone have a 3 or 4 axis post processor for a 90's Haas VF (4 I think). Or do you know what name I should be searching for? Tried PosteHaste and searching google and forums with little luck.
    Jun 2006
    29
    Try doing a search in the Gibbs directory for file extension *.pst. If that returns nothing, expand your search to more directories, but be aware that Windows recognizes .pst as a Office file extension, so you may get a lot of unrelated results.
    As for the post name, generally they follow this format: "Fanuc 18T OH VTM-80 [AG] L3682.18.2" which covers the make (Okuma-Howe), model (VTM-80), control (Fanuc 18T), and type of machine (L=Lathe, M=Mill), as well as company abbreviation in [] brackets and the revision number of your post (3682.18.2). Yours may vary, but it will probably look something like that.
    Hope that helps!
  1. Need gibbscam post file.
    By randypage in forum GibbsCAM
    Last Post: 05-23-2012, 05:08 PM
  2. SmartCam 11 post for Mach 3
    By Parameter in forum Uncategorised CAM Discussion
    Last Post: 02-06-2011, 05:23 PM
