585,749 active members*
4,071 visitors online*
    May 2013
    32
    Series 1 limit switches
    Does anyone have any pictures or a link showing the series 1 limit switches installed.
    I bought my Series 1 without the switches or control system. I see that the Z switch must install under the cover on the head, but have no clue how the others install.
    I have been running it without limit switches for a few months but I almost crashed it hard today. I am sure I can rig something up but it would be nice to see how the factory did it (or how others did it).
    Thanks.
    Sep 2011
    38
    pic seris 1
    my boss 5
    Quote Originally Posted by boss4 View Post
    Thanks.
    Feb 2007
    198
    Your mounting holes for the switches and the "L" tab which trips the switch should be there. I believe Automation Direct limit switches have the same bolt pattern as the original switches.
    Apr 2010
    486
    Quote Originally Posted by polaraligned View Post
    I just bought a limit switch from Automation Direct. It fits just fine, but is NOT the right switch.
    Haven't found the right switch yet, but the original switch opens (or closes) at 10 degrees of rotation. The AD switch opens or closes at about 45 degrees of rotation. This allow the table to crash before the switch opens.
    The part number on the original switch is LSP3K. That gets you the switch body, but not the actuator arm.
    Anyone got a source for the entire unit?
    Tom
    Feb 2007
    198
    Interesting. I have used the AD switches on my Series 2 BP and was able to get them to work fine.
  1. E-Stop,Limit Switches - Car door open switches ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 04-19-2012, 09:55 PM
  2. Series Limit Switches with Shielded Wire
    By Wolfspaw in forum DIY CNC Router Table Machines
    Last Post: 12-27-2011, 09:54 PM
  3. Bridgeport Series II Interact 2 EMC retrofit -- limit switches
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2010, 01:15 AM
  4. Help with Bridgeport Interact Series 1 MK2 Stuck on the Limit Switches
    By mwibbels in forum Bridgeport / Hardinge Mills
    Last Post: 02-05-2009, 09:33 PM
  5. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
