585,977 active members*
4,138 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > A little fuzzy on edge chamfering...
    673
    So, if I want to chamfer an outside edge of a part and do it in cam, how does that work on the machine? Do I set my tool height at the tip of the tool, and some how Mach knows how far down to run the tool and how far to offset it? Not sure how that whole chain works and how any of it knows how deep to set the tool....
    (I Use SolidWorks and do model the chamfer there, HSM Express, and of course Mach3 on the Tormach)
    TIA...
    Feb 2008
    389
    Not familiar with HSM Express but in the cam software I have, with a 2D contouring op. you can pic the top surface as "top level" then adjust the contact point of the cutter.
    Does HSM Express have similar adjustments?
    Maybe this screen cap will help explain?
    Attachment 186194
    Currently using SC7 Build 1.6 Rev. 64105
    Dec 2007
    101
    Jul 2006
    525
    When you select a chamfer tool in HSMXpress/works on a 2d contour operation, a "chamfer" checkbox will appear on the operations settings page, which will ask you for a chamfer width (which, if the chamfer is modeled, you'll leave at zero) and an "offset", which offsets in both x/y & z. Its simplest to use "in computer" compensation for th
    673
    Thanks folks, I think I can figure from there.
  1. Replies: 12
    Last Post: 01-29-2013, 02:33 AM
  2. Help me stop cutting fuzzy threads!
    By mioduz in forum MetalWork Discussion
    Last Post: 06-17-2012, 04:58 PM
  3. Warm and Fuzzy
    By cncadmin in forum EnRoute
    Last Post: 04-18-2012, 06:40 AM
  4. Chamfering Help Please!!
    By Randy727 in forum Solidworks
    Last Post: 07-22-2010, 11:27 PM
  5. Fuzzy Oscilloscope readings.
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 03-27-2005, 12:49 AM
