585,902 active members*
4,219 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > This looks like it will make for a very small/clean PC for CNC (Mach3 or Linux CNC)!
    Feb 2009
    2143
    Gigabyte's Brix mini PC to challenge Intel's Next Unit of Computing - The Tech Report
    Any low end version should do fine, and if the Intel branded ones are only $135, I would expect the Gigabyte ones to be even less :banana:
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Mar 2013
    12
    Nice. Small form factor will allow for a much cleaner work area.
    1943
    With no parallel port you will have to have a separate motion controller.
  1. Can I make a small suggestion?
    By maspeir in forum Videos
    Last Post: 04-09-2011, 04:04 AM
  2. Linux/EMC VS Mach3 Where to Start
    By Gads in forum LinuxCNC (formerly EMC2)
    Last Post: 01-29-2008, 03:46 PM
  3. Anyone try mach3 with linux/wine
    By timmyb199 in forum Machines running Mach Software
    Last Post: 10-23-2006, 07:32 AM
  4. Looking for some one to make small cap object.
    By dbtoutfit in forum Employment Opportunity
    Last Post: 03-30-2006, 12:45 AM
  5. Looking for some one to make small cap object.
    By dbtoutfit in forum MetalWork Discussion
    Last Post: 03-06-2006, 09:48 PM
