585,974 active members*
4,359 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > The New Chinese metal working spindles
Results 1 to 12 of 12
    Jun 2012
    35
    Hello all,
    I've been in the market for a Chinese spindle lately and have noticed that a few new "metal working" spindles have popped up in the market that are supposed to endure being able to cut metal. I'm mainly cutting wood and acrylic, but would also like to be able to cut alum sheet, and SS/steel sheet up to 16ga. Also Alum profiling. I have a steel machine.
    Anyhoo, Was wondering what, is any of you, have had any experiences with the new breed of Chinese spindles. They are about 3x as much as their counterparts.
    Thanks in advance,
    CC
    2 2KW CNC Router Metal Work Water Cooling Spindle Motor | eBay
    3KW New Water Cooled Spindle Motor Special for Metal | eBay
    Oct 2012
    70
    Very interesting... This is the first I've heard of these spindles.
    I too am interested in other's feedback...
    Feb 2009
    118
    I had one ... bought it about 6 months ago from the same seller ... very quiet , but not as good as advertised .
    A much better choise would be this :
    2 2KW "Hertz Brand" Spindle Motor Air Cooled | eBay
    I have tested theese turkish motors ... measured TIR under 0.01mm ( with a Technics ER16 collet and a Viper 4mm carbide endmill ) .
    Cuts aluminum like a charm . Use a bit of WD-40 for a mirror like finish .
    Oct 2012
    70
    what's the noise level of that spindle compared to the chinese water-cooled ones?
    Feb 2009
    118
    Being an air cooled motor , is a bit noisier , of course ... The chinese motor is really quiet , cuts aluminum very well ,
    it's a bit heavier than ordinary chinese motors ( at the same specs ) ... but I don't like it . Is harder to make a mounting bracket ,
    it needs a cooling system ( cooling agent , pumps , hoses / pipes , tank ... ) . The turkish motor has a very decent price/quality ratio ,
    easy to use / mount ...and is not chinese !!! ( for me , that's a big quality ... )
    Jun 2012
    35
    Does it make a difference it being 2.2kw compared to the 3kw chinese spindle?
    Feb 2009
    118
    Can't say ... I have never used a 3Kw spindle , only 2.2 ... Never needed a more powerful spindle for machining aluminum .
    Cheap chinese spindle are low quality ... weak bearings , astronomic TIR , poor quality components overall . If you want a dependable
    machine , you need to spend a little money ... Just my opinion ...
    Nov 2006
    1036
    Quote Originally Posted by katran View Post
    It looks like you also bought a .75kW Hertz spindle from eBay. Have you used that to mill aluminum too?
    Jan 2013
    14
    What rpm/tooling are you using to cut aluminum? How slow can you safely run these Turkish motors?
    Bart
    Jan 2007
    1795
    they are giving an extra set bearing.. also look for photos.. what they offer for metal, those has 2 bearing on the front.. you can see the front differ some from the other spindles..
    you can ask seller take a photo bout bearings,, can happen they are nsk or fag bearings.. if so, then price is very reasonable..
    since these has more bearing they migth noisier than other spindles.. yet way better option than a handheld router..
    Nov 2006
    1036
    Wrote to the ebay seller of the Hertz spindles twice today. Very quick answer to both inquiries. Sadly, it appears that he does not recommend using his .75kW spindle for milling aluminum.
    Here's our last exchange of messages:
    Dear donframbach,
    ok. please place order. But don't pay. I will update the invoice.
    This spindle motor very good in wood. For aluminum; you should make cooling.
    Best Regards.
    - ceocnc
    To: ceocnc
    Subject: Re: Other: donframbach sent a message about 0.75KW "HERTZ BRAND" SPINDLE MOTOR AIR COOLED #221200414106
    Sent Date: Jun-02-13 10:21:10 PDT
    Dear ceocnc,
    Thanks for your quick answer!! To buy the 24k rpm spindle from you would I just buy the 18k rpm through ebay and then add another $25 at checkout?
    Also, do you recommend your spindle for light milling of aluminum or just for wood?
    - donframbach
    Feb 2009
    118
    Indeed , I bought 0.75Kw spindles ... tested in aluminum with good results ( 0.5mm depth of cut , 30mm/sec feed , about 8000rpm , 4mm carbide cutter ) .
    Here is the flic :
    aluminum milling test - YouTube
    and this is the machined piece of aluminum at the end ...
    hope that helps ...
  1. Any reasonably priced (cheap) spindles other than the chinese spindles?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 11-05-2014, 11:16 PM
  2. Chinese spindles
    By rozpiur in forum Uncategorised MetalWorking Machines
    Last Post: 10-09-2011, 03:08 PM
  3. Weight of 0.8/1.5 kw chinese spindles
    By iwik in forum Phase Converters
    Last Post: 06-03-2011, 11:29 PM
  4. Chinese Spindles
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-26-2011, 02:05 AM
  5. Chinese Spindles
    By kthomson in forum DIY CNC Router Table Machines
    Last Post: 02-16-2010, 03:46 AM
