585,971 active members*
4,250 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > video of test cut on mill i might buy..is this good?
Results 1 to 7 of 7
    Dec 2012
    569
    its a Miyano MSV21
    i might be able to get it for around $5500 shipped
    seems like alot of chatter for 0.003" chipload in cold rolled steel..chatter doesnt seem to start until it plunges another 0.125" deep seems like there is already 0.125" pass done before video starts. skip to 1:26 in the video to see when the chatter starts.
    but im not that experienced with this sort of cut....
    the video description is:
    "This is a test cut on a Miyano MSV-21 CNC mill cut cold rolled steel with a .499 4 flute carbide end at 1,500 rpm, taking 4 .125 deep cuts at 12 IPM and leaving .005 on the side walls. The finish cut was at 6 IPM. It was programmed to cut a 4" X 4" square. The block measured 4.001 in both the X and Y directions. If the cut had been .500 the machine would have cut it right on size."
    the video shows two types of cuts, as described. i watched the whole video and its basically the same chatter throughout the 0.125" depth cut, but when it gets to the finish cut its very quiet (just sort of intermittent chunk sounds..im guessing thats the much larger chips hitting the enclosure)
    does this seem good?
    Jan 2004
    3154
    I dont notice any chatter but I think it needs a new spindle/bearings.
    SFM is way low and not enough chip load (that is only .002).
    AT least 3000RPM at 30-40 IPM would work better
    www.integratedmechanical.ca
    Dec 2012
    569
    Quote Originally Posted by DareBee View Post
    does this chatter seem appropriate then?
    can someone with a brand new haas take the same cut in the same material with the same cutter and upload a video of it so i can hear the chatter plzzzz? hahhahahah
    Jan 2004
    3154
    Read
    Dec 2012
    569
    Read
    Jan 2006
    2985
    Quote Originally Posted by acannell View Post
    Read
    He obviously heard the noise and told you he thinks the spindle needs new bearings. He wasn't being an @ss, just trying to make you realize what he is saying. Do you realize that rebuilding the spindle will cost about as much as you are paying for the whole machine?
    Dec 2012
    569
    Quote Originally Posted by keebler303 View Post
    gross.
  1. Laser Powersupply Signal Test Video
    By Gweikelasers in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-10-2012, 07:25 AM
  2. here is my driver test,is this good
    By namso in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2010, 10:50 PM
  3. nm070 test video
    By ihavenofish in forum Novakon
    Last Post: 05-19-2009, 10:17 PM
  4. New Ceramics grinding Test on CNC video Forum
    By Astonlee in forum MetalWork Discussion
    Last Post: 11-14-2008, 09:56 PM
