Currently evaluating Solidcam ,Hsm works has unfortunately lost a lot of its resellers in the uk
So we have a hurco with winmax control, not using conversational it is set up to read isnc
model a basic part and use solidcam to generate toolpaths...fine
run simulation....fine...sharp corners (basically a cube)
post using 3x mill generic evaluation post ....fine
load into hurco ,no problems ,verify with hurco graphics and the part is big with rads on the corners as if the cutter gomp is not being applied
or it is being applied a long way off the true boundary of the part
to check its not the graphics part was cut and came out as the hurco graphics verification
Its as if the output gcode has already taken into account the g41 (comp on) and is then leaving the control no work to do as in all computations are done in the pc and output as opposed to letting the control do the cutter comp (in control)
Im wondering if its a setting in solidcam as the toolpath is ok and i read through the code
Completely puzzled as HSMexpress using a fanuc post has cut everything fine
Any hints tips?
thanks
