585,875 active members*
4,179 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > HElp needed to connect breakout board to drivers
    Oct 2012
    13
    Hello I'm newbee so please help
    I have HY-JK02-M 5
    http://softsolder.files.wordpress.co...ion-labels.jpg
    and 4 :
    HY-DIV268N
    TB6600 5A Single Axis 5A CNC Stepper Driver
    http://www.goodluckbuy.com/images/de...ku_88141_3.jpg
    can you show me how to connect them to each other? 4 drivers must be connected to breakout board
    Jan 2010
    2141
    There are perhaps a couple of ways that you could hook up the drivers to the breakout board (and I do not have documentation for your breakout board or drivers, so this is my best guess).
    Try this:
    - hook up DIR+, PUL+, and EN+ to a +5 volt power supply
    - connect DIR- to XD for x-axis (YD for y axis, ZD for z-axis, AD for a-axis)
    - connect PUL- to XS for x-axis (YS for y axis, ZS for z-axis, AS for a-axis)
    some of these drivers will enable properly with no connection to the enable input, or you could connect EN- to XE for x-axis (YE for y-axis, ZE for z-axis, AE for a-axis).
    Make sure that you are supplying 5 volt power to the breakout board, either through a USB cable or via the direct power input terminal.
    Jan 2009
    16
    Would like to know how you make out. I have the same breakout board and am considering similar driver boards with the same connections. Found this diagram if this helps.Attachment 187622 And this note: Figure 2. Input interface circuit (common cathode connection)
    Note: the VCC is 5V, R short;
    VCC value of 12V, R 1K, more than 1/8W resistor;
    VCC value of 24V, R 2K, more than 1/8W resistor;
    R Must be connected to the controller output terminal
  1. Motors, Drivers & Breakout Board Wiring
    By OnezerO in forum Stepper Motors / Drives
    Last Post: 07-24-2014, 11:21 PM
  2. Connecting Breakout board to Stepper Drivers
    By leprosylv in forum Stepper Motors / Drives
    Last Post: 05-07-2013, 04:25 PM
  3. Fried Probotix Breakout board or drivers?
    By pippin88 in forum Stepper Motors / Drives
    Last Post: 09-25-2012, 11:13 AM
  4. Fried Probotix Breakout board or drivers?
    By pippin88 in forum DIY CNC Router Table Machines
    Last Post: 09-10-2012, 01:34 AM
  5. How to connect breakout board to stepper motor drivers?
    By jeffmorris in forum Stepper Motors / Drives
    Last Post: 06-27-2012, 09:25 PM
