I am assuming that it was powered up in the usual way? IOW the machine was not reconnected for your benefit?
The reason is that these machines are phase rotation sensitive, so keep this in mind if you to hook it up at new premises.
I also show 38.4 as the dedicated Estop, it has an asterisk next to the designation that indicates this is active inverted state.
Make sure you get all documentation with the machine, these have bubble memory so there is not usually a worry about memory loss when powered down for some time.
Also the thing to check as a prevention is the servo & spindle brushes, $25 saves $2,500 in motor replacement!
Al.
Albert E.
