585,599 active members*
3,670 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Best bit for engraving on ceramic tile?
Results 1 to 11 of 11
    Dec 2010
    I have tried several different bits but have yet to find one that does a good job engraving on ceramic tile. Any place to buy good bits for this appcation?
    Anybody been able to answer this? I would also like to know what type of bit to use for Ceramic tiles? And, would cooling be necessary? I tried a cheap diamond dusted bit, but basically melted that, and it barely cut for about an inch... :-)
    Apr 2004
    5731
    Engraving on fired ceramic tiles is not something people normally do. There's a lot of variability in them, so a tool that might work well on a low-fired unglazed tile could totally melt down on high-fired glazed stoneware or porcelain. It would also compromise the functionality of the tile by breaking up the smooth surface. Why do you need to do this? Wouldn't it be better to start with unfired tiles and glaze them afterwards? If you really need to engrave on fired tiles for some reason, what sort of tiles are they? How deep are you trying to cut? What line thicknesses are you trying to achieve?
    Andrew Werby
    www.computersculpture.com
    Jan 2007
    1795
    glazed tiles might don't work..
    as awerby pointed out they are glasslike, hard and very brittle.. with a diamond wheel you can make groves.. elongated groves .. there are some resinbond diamond grinders, pointed 90-120 deg but with them it keeps forever..
    unglazed tiles can be made like marble or other hard stones.. its called pcd or polycristalldiamond tool.. artificial diamond..
    Jan 2007
    1795
    you can find from 20-30 up to 500 or more..
    they are expenses, but for stone they are the only tool..
    Pcd Engraving Bits, Pcd Engraving Bits Products, Pcd Engraving Bits Suppliers and Manufacturers at Alibaba.com
    most seller sell 10-20 at time only.. some of them sell invidually..
    brands like amana or onsrud also have pcd tool they start somewhere 200-300 each tool..
    Thanks. Basically, the answer here is DON'T. I wanted to scribe lines for an Art Project I had in mind. I melted a few diamond bits and also one Tungsten Carbide bit. I'll change my target media to Wood or Soft Soapstone. Thanks for the advise.
    Jan 2007
    1795
    I just found a store for invidual engravingbits..
    yet low priced..
    2pcs 6mm 90D Conical Flat PCD Carving Bits, Stone Engraving Bits on Hard Granite,Jade,Brick
    2 pcs bit is 51 ... I don't know how much the actual shipping but this is a very good price for pcd bit..
    long time we used pcd in automotive shop to finishing pistons.. by heat the pcd insert separated,,, so be careful to using..
    you can give a try yet.. who knows it might works..
    Apr 2012
    63
    Re: Best bit for engraving on ceramic tile?
    link here, PCD for stones, and for wood work, woodworking toos are here,
    CNC routers and accessaries
    www.tayoutec.com
    Ok. Melting diamond bit or machining tungsten carbide bit would have been helpful.
    Jul 2017
    Quote Originally Posted by toodark View Post
    I am glad I didn’t read this thread before trying. I used a carbide drill spinning at 3000K rmp. I fed at 1”/min and plunged at .5” /min. I was able to cut two ceramic tiles and the cutter is still sharp.
    Attached Thumbnails Attached Thumbnails 546FBC8D-3099-48E2-A0E2-082476E4AF82.jpg
    Dec 2013
    5717
    Quote Originally Posted by Colinsk View Post
    Looks like you found the right combination. Slow spindle speed and reasonable feed. Guessing you did these on a mill rather than a router. :cheers:
    I've done glass on a mill, about the same conditions.
  1. Cutting Ceramic Tile ô¿ô
    By lockeyone in forum Hobby Discussion
    Last Post: 04-26-2016, 12:18 PM
  2. ceramic tile ??
    By cyclestart in forum DIY CNC Router Table Machines
    Last Post: 07-04-2013, 11:25 PM
  3. Wood +Glass+Tile Cnc
    By crosswinds in forum Engraving Machines
    Last Post: 01-26-2008, 06:18 PM
  4. Anyone cutting carpeting or tile?
    By Matt B in forum Material Machining Solutions
    Last Post: 12-27-2005, 06:27 PM
  5. Printing on hard surface tile?
    By jeffterm in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-01-2004, 11:32 PM
