584,800 active members*
4,344 visitors online*
    Apr 2005
    85
    What's the difference?
    What's the difference between an AC and a DC stepper?
    I was at the local salvage store today and found some Slo-Syn SS91 AC Syncrohous Stepper motors. I bought one for the motor mount and hardware attached. I found this link that lists the specs for the motor but I don't think I've read anything about AC steppers. Any help would be appreciated.
    AC synchronous steppers run at a constant speed of 72rpm. Not suitable for a cnc.
    Apr 2005
    85
    Gotcha! Thanks. At least the Nema23 mount is good. Just curious, what would one do with such a motor? Maybe a small turntable for DIY 3D Imaging?
    24216
    Quote Originally Posted by ignatz
    They are often used in assembly line operations and processes because of their synchronization to the incoming supply 72rpm for 60hz or 60rpm for 50hz.
    They have identical construction to 'DC' steppers, also like a stepper they have good holding torque at zero speed and they can be held in position when the AC is removed by injecting a DC voltage into the windings.
    Al.
    Albert E.
    Aug 2004
    2849
    And of course the obvious....one is AC and the other is DC...
