585,754 active members*
3,916 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > Charmilles Robofil 300 Generator Parameters for rough and skim????
    Oct 2011
    5
    Question Charmilles Robofil 300 Generator Parameters for rough and skim????
    Hey guy's! Can someone confirm your Rough settings in Generator Parameters, and the Skim settings: I had to reload my software and .tec files and my machine is suddenly running 1/4 of the speed it used to. Cutting around 2.75 In/hour for a .75" thick 3/8 dowel!!!! Used to take me around 15 minutes for the rough and the skim. I am at 15 and only half way done with the rough?
    Here are my settings for Rough, Skim (this is for .75" thick 4140 hardened steel).
    E 501
    EL:15
    PA:6
    ST:1
    M:1
    V:-80
    IAL:16
    B:4.0
    A:1.0
    TAC: 0.8
    AJ:40.0
    S:10.000
    INJ: 4
    WB:1.00
    WS:13.0
    FF:100
    % ST 1 GAUGE IS PEGGED AT 75 MAX?
    SKIM CUT SETTINGS:
    E 502
    EL:15
    PA:6
    ST:2
    M:3
    V:-120
    IAL:16
    B:3.8
    A:0.2
    TAC: 0.2
    AJ:80.2
    S:2.190
    INJ: 0
    WB:1.60
    WS:8.0
    FF:100
    Extremely slow.
    Please Help. -Jeremy
    Jan 2006
    104
    are you using CT-EXPERT to create tech?
    Or are you using predefined tech?
    is this a "Brass" generator?
    try :
    B 7.3
    A .9
    M 21 (for rough cut, and 23 for skim cut), 1 and 3 seem to be incorrect. this should bring the strategy down......
    other than that your tech looks okay.
    are you absolutely sure that your technology disk matches you com disk?
    the wrong version tech in the machine will give poor results.
    i would suggest using CT-EXPERT to create tech.
    are you giving the part height anywhere in the g-code (REX,E2,H0.75)
    Registered Linux User #348337
    EMC2 Rocks!!!!
    Oct 2011
    5
    Thanks, Is there anyway I can set these values in mastercam x5 power settings? So when I select the power file they are set for the condition code?
  1. Charmilles Robofil 200 startup
    By Shawn Lucas in forum EDM Discussion General Topics
    Last Post: 07-23-2021, 12:20 PM
  2. charmilles robofil 440 post
    By JCrafton in forum Mastercam
    Last Post: 04-29-2014, 02:37 PM
  3. charmilles Robofil 190 or charmilles Robofil 290
    By Fontez in forum Post Processors for MC
    Last Post: 03-12-2013, 04:48 PM
  4. Charmilles Robofil 200 programs
    Last Post: 04-02-2012, 10:07 AM
