585,888 active members*
4,430 visitors online*
    Jan 2006
    48
    need help with tos milling machine
    Hello everyone I have a tos fnk25 vertical milling machine and wish to convert it too cnc .I am a bit stumped as regard the size of stepper motors, I require, can anyone help?
    here are some figures i worked out
    require 640oz/ins when load applied to x axis
    would like to have 2 to 1 gearing
    max 833 steps/second with gearing
    according to gecko site
    this relates to 163 watts of power need to move the axis
    833 x 640 divided by a factor of 4500 plus 40 percent
    have i work this out right?
    how do i now pick the most efficent motor?
    if i go oversize on the stpeper motor .can i reduce the voltage to compensate thus reducing the power?
    all the best Derk on the Isle of Wight (uk)
    Feb 2021
    Re: need help with tos milling machine
    Googled TOS FNK 25 CNC Conversion and this was pretty much the only post I could find....
    What's the most random part of it, is that I also live on the Isle of Wight and didn't realise Derk was doing a conversion on the same machine.
    Has anyone else done one since?
    Cheers
  1. Need a Machine Manual for a Comet Milling Machine
    By metalman7290 in forum Machinery Manuals / Brochures
    Last Post: 09-12-2020, 06:56 PM
  2. Milling a plastic with a CNC 770 milling machine
    By Edmond Young in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-12-2013, 02:55 PM
  3. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
