585,605 active members*
3,180 visitors online*
    Dec 2009
    952
    fanuc 16i renishaw macro
    i use on a machine with fanuc 16 i the renishaw for measuring tool with the macro program O9853 with the corespondent prgrams O9799,9850,9851,O9852
    the programs are working corect but when the renishaw measure the diameter of the tool,the measured value is set also on lengh offset so if i measure one tool it puts on number 1 tool the lenght and the diameter on position 2 but the diameter should be written on D offset not on lenght offset.
    if anyone knows how to changed it will be fine
    the macro programs are for 0i and the fanuc 0i doesnt have the D OFFSET so i think the macro must be change a little but dont know what to change.
    thank you
    Dec 2009
    952
    nevermind i got it work easily
    when you use fanuc 0i you have to call the program with A1---type of the offset
    i had to call the macro with B2 because i had 16iM
    so when you have only lengt offset you have to use A1 and when you have lenght and radius also on the offset table you have to ccall the macro with B2
  1. fanuc 16i renishaw macro need it
    By zavateandu in forum Fanuc
    Last Post: 05-23-2013, 08:41 AM
  2. Fanuc oi md - renishaw probe
    By Debo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-20-2010, 09:48 PM
  3. Replies: 2
    Last Post: 03-27-2009, 09:15 PM
  4. Convert Fanuc Macro to Fadal Macro
    By bfoster59 in forum Fadal
    Last Post: 11-09-2007, 06:41 AM
  5. Fanuc 21MB & Renishaw MP40
    By Andrew_K in forum Fanuc
    Last Post: 02-22-2006, 04:07 PM
