Another forum participant sent me the following inquiry in a private message:
I can only speculate that there is more to that story. In general, the point of the Ajax DIY division is to sell component-level controls to qualified DIY builders.Last year about this time I had a cquired a V2XT. I wanted to get it running with a centroid all in one unit. Guys from ajax refused to sell to me because they wanted me to buy their everything included ready to bolt on cabinet.
A Centroid control would address most of those concerns. You do still need to tune the servo loop, but it is not as tedious a process as it is with analog drives.I went with a MACH system that has left a very bad taste in my mouth. Loop only closed between driver and servo, limit switches sensitive to VFD, drivers sensitive to VFD, Lost steps during rapid, Homing relies 100% on switch and not on index off of encoder, need to tune servo motors.
The depends on what "lightly buzz" means. We commonly tolerate a low level of buzz or whine, as a tradeoff in performance and accuracy. It is usually possible to silence the motors when sitting still, but at the cost of backing off on all the PID gains and accepting higher error spikes at the beginning and end of each move.In addition my motors seem to lightly buzz after moving in certain directions. One person told me bad bearings, armature needs to be skimmed and rebalanced.
If your motors buzz, or don't buzz, depending on what move was just done, that is probably just due to friction in the ways. Sometimes when the motor comes to a stop there may be more tension in the drive train, sometimes less.
Probably not, but it depends on your belt ratios. If your axes are direct coupled or belted 1:1, then yes, you can probably exceed 300 in/min. If your axes are belted 2:1 (common on many Bridgeport knee mills) then your rapids will be around 180 in/min.Will this give me 300 IPM Rapids, .0005 tolerances, ...
Whether you can maintain 0.0005" tolerances has less to do with the control system, and more to do with the machine, the tooling, and the fixturing. If your machine has negligible mechanical backlash, low static friction (stick/slip), and ideally 2:1 belting, then you should be able to maintain 0.0005" or better fairly easily.
If you have 0.001" backlash, sticky ways, binding gibs, sloppy fixtures and dull cutters, then the best control in the world won't get you within 0.002".
Maybe. It depends on how noisy your VFD is, and how careful you are with your wiring procedures.... is teh all in one sensitive to interference from my VFD in the cabinet?
In general, using good quality inverters (e.g. Yaskawa, but also the Delta drives from Automation Direct), and using reasonable care in wiring (e.g. ensuring that encoder cables and input signal cables are shielded, that the shields are properly grounded, and that such cables are kept away from the outgoing spindle motor power wiring), I have not had many noise problems.
On the systems where I have had noise problems, it has generally shown up as one of two things:
1) Distortion of the analog spindle speed command (0-10V from the PLC to the VFD) on some OEM machines where there was a speed meter on the head, wired to an analog output from a Delta inverter, with said analog wiring routed alongside the spindle motor power wiring; or
2) Encoder quadrature errors, due to encoder cabling (even though shielded) routed too close to spindle motor power wiring in retrofits of machines with older spindle drives (ca. 1996 Yaskawa G3 in two cases, ca. 1987 Fanuc -6055 drive in another case).
It will if you write custom M3 and M4 macros to make it do that.I also have a macro and brain combination that stops my programs and tells me when I need to change spindle gears according to commanded speed. Will centroid system do that?
For example, assuming you have a range detect switch wired to INP7, closed in low gear, and you want to use low gear for anything below 350 RPM, you might put something like this in an M3 macro (file named mfunc3.mac):
Code:M95/1/2 IF [#4119 < 350 && #50007==0] THEN M200 "Shift to low gear and press Cycle Start" IF [#4119 >= 350 && #50007==1] THEN M200 "Shift to high gear and press Cycle Start" M94/1In short, no.I would also like to put a servo on my knee for tool length offsets and use that axis for axial DOC steps. Can I get a plug in or macro for TLO on a kne servo?
The control is inherently a G code interpreter. It moves the axes that your CNC program tells it to move. There can be only one Z axis. If you want to set up a W axis as well, you can command W to move any way you want, using the appropriate G code commands in your program. The control, however, is not going to decide to move W sometimes when you command Z, and not other times.
See the comments and suggestions in this thread: http://www.cnczone.com/forums/ajaxcn...ml#post1070854
