585,997 active members*
4,925 visitors online*
Page 5 of 6 3456
Results 81 to 100 of 113
  1. #81
    Jun 2011
    695
    Re: Hurco KMB1 upgrade
    New updates. Planning on going with Cetroid Acorn controller.
    https://youtu.be/o4ARjFxwsLI
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  2. #82
    Oct 2008
    2100
    Quote Originally Posted by FannBlade View Post
    Nice. Looking forward to your results.
    Bob La Londe
    http://www.YumaBassMan.com
  3. #83
    Oct 2008
    2100
    Ultimately I've taken my KMB1 back to its original (more or less) retrofit state. I'd greatly benefit from a faster spindle. Of course I can slap a companion spindle on it, but that's not a real answer. I've got three small Speedmaster mills with 24K spindles for the majority of my high speed machining. I'd just like to bump the spindle speed on the Hurco up a bit. Its fine when I am roughing steel, but most of the time I am cutting aluminum. 3600rpm is like riding a snail. I think the spindle could take a lot more, but I'm not so sure about the motor. Its got an old Leland 5HP 4 pole motor and the mill manual derates it to 4HP. Seems reasonable. Its running a 3.7kw spindle off single phase, and I just set all my calculations to a max of 3HP. Really though I rarely break one horsepower except on those rare occasions when I actually am roughing steel stock. I'd really benefit from getting it up to 5000-6000 rpm. In many cases my lowly Tormach 1100 will outproduce the KMB1 because the Tormach has a 5000+ rpm spindle even if it doesn't accelerate as fast or have as big of a spindle motor.
    Anyway, I think the New Departure and Fafnir bearings in the KMB1 spindle could handle more RPM.
    ( I put new (old stock) bearings in it a while back )
    I'm just not sure the motor could. I'm putting 120hz to the motor now to get 3600 RPM. The motor is connected to the quill with a 1:1 timing pulley setup.
    So, has anybody cranked up the speed on your KMB1 spindle? How did you do it? How did it work out?
    Bob La Londe
  4. #84
    Oct 2008
    2100
    Well, I need a faster spindle so I thik I'm just going to adjust the VFD to put out 200Hz and run it. If the motor craps out I'll put another motor on it. If the spindle craps out I'll rebuild it again. I already have another spare set of bearings for it.
    There now I have announced what I am going to do. Maybe some of the after nannies will tell me how stupid it is. LOL.
    Bob La Londe
  5. #85
    Jun 2008
    1104
    You could get a 6000 RPM option for those anyway so I doubt the mecanical side of things would let you down. Motor-wise, It’ll either fly or die...
    Go for it! ??
  6. #86
    Jun 2011
    695
    Speaking of RPM I'm looking for a 3600 RPM motor running with 2-1 pulleys. I too may be out of my mind,but I agree it will need more RPM.
    Hurco KMB1 Build
    C-Constant
    N-Nonworking
    C-Contraption
  7. #87
    Jun 2011
    695
    Finally in paint!! I amaze myself what I can do in five years!!
  8. #88
    Jun 2011
    695
    More pics
  9. #89
    Jun 2011
    695
    yep even more!
  10. #90
    Mar 2011
    9
    That's a great shade of blue! Five years is a long time. Nice to see the results thought.
  11. #91
    Oct 2008
    2100
    Ummm.... Do you realize the head was supposed to swivel from left to right and extend or retract as needed to reach a much larger work envelope? It looks like you painted the swivel shut and painted the sliding dovetail of the head. 14 x 24 seems like a lot... until you need more. The swivel and extension of the head gives you easily twice that range. Its is a really pretty paint job though.
    Bob La Londe
  12. #92
    Jun 2011
    695
    Hey Bob
    You are right I did paint it all,but I did plan on it....you have a camera in my shop????
    I will be pulling the head off completely for the move and hope I can get it to move. I have tried everything to get it sliding again,so I hope when I lift it I can get it to break loose and get it lubed properly.
    In the meantime I have started on the assembly process. NO electronics will be install until it gets move and hope it doesn't get scratched up to much!!!
  13. #93
    Oct 2008
    2100
    Was that tape in the previous photos or did you clean off the paint? Also, it still looks like the swivel mechanism is painted over.
    Bob La Londe
  14. #94
    Jun 2011
    695
    Yep just razor bladed off. It was not sanded just wiped clean so it would come off easy. I will cut the seam on the swivel and hope it doesn't look to bad. I have to get everything painted because I won't be painting in the new shop...I don't want to ruin the shiny epoxy floor.
  15. #95
    Oct 2008
    2100
    Visqueen paint booth and a respirator.
    Bob La Londe
  16. #96
    Jun 2011
    695
    Yes. Covered everything in shop and used respirator.
    I see Centroid just released V4 of the Acorn board. Really good price with all the new items. Board,relays,power supply,network cable,software and wiring. I will bump up to paid version on the software to get rigid tapping.
    Acorn CNC controller, Step and Direction 4 axis CNC Control board with ethernet communication.DIY CNC kit
  17. #97
    Mar 2011
    9
    What are you going to use to convert the acorn's step and direction signals into the dc servo drive signals?
  18. #98
    Oct 2008
    2100
    As to moving the head.... You have to loosen the cross bolts, and tap the side with the nuts towards the head, and then, in theory, you can move the head. The head is very heavy and it tends to be a little stuck in place from dried coolant spray, misc debris, and (eh-hem) paint residue. Sometimes mine moves ok, and sometims I have to put a block of wood against it and beat on it with a 3lb machinist hammer.
    Bob La Londe
  19. #99
    Jun 2011
    695
    Quote Originally Posted by Ninensei View Post
    Right now I'm planing on Viper drives with 160 volt Antec power supply,
    Viper Servo Motor control products
  20. #100
    Jun 2011
    695
    Quote Originally Posted by Bob La Londe View Post
    I'm hoping when I put a lifting bar in I can break it all loose when I lift the head off base. I've had all the bolt loose and out to clean paint off, I'm going to re-clean them and powdercoat them before I reinstall them.
    With it separated I should be able to move it on a trailer myself. My doors are 8 ft,so it barley fits through. I hope I can get a trailer in shop and lift it with a gantry crane.
Page 5 of 6 3456
  1. hurco kmb1
    By adee1066 in forum HURCO
    Last Post: 06-26-2011, 07:47 AM
  2. Hurco kmb1
    By Dfoxaldee in forum HURCO
    Last Post: 10-29-2009, 03:27 PM
  3. Hurco KMB1 dnc
    By mmachining in forum DNC Problems and Solutions
    Last Post: 01-25-2007, 05:06 AM
  4. Hurco KMB1 with bx upgrade
    By jpcuttergrinder in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-15-2006, 04:38 AM
  5. Hurco kmb1 BTR ???
    By drill in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-10-2006, 06:42 PM
