585,908 active members*
3,879 visitors online*
IndustryArena Forum > CAM Software > Vectric > Help with routing HDPE Signboard
    Oct 2008
    14
    So I am trying to make plaques for my son's baseball team. I am using 1/2" thick HDPE Signboard that is white on the outside and black core. When I use a 90deg V bit with a single pass it looks great. My issue is when I use a 30deg V bit after using an endmill for the flats it creates a lot of little cones that stay connected at the base of the 30deg V bit cut. I'm thinking about running the 30deg V bit first and then the endmill to finish out the flat bottom pocket. This will reduce the cones or hairs but not eliminate them, I think.
    Take a look at the pics. The logo is a very shaky looking font. The 2013, name, and players name is done with a 90deg V bit with no issues. I'm using V Carve. Anyone have any ideas on how to reduce the cones? Or di I see a lot of manual cleanup in my future?
    Thanks in advance,
    James
    http://i216.photobucket.com/albums/c...ps8f70fbc1.jpg
    http://i216.photobucket.com/albums/c...ps7d9077b5.jpg
    Oct 2006
    259
    A - What is your toolpath feed & speed & router RPM ?
    B - In my opinion, I'd try also what your thinking.....V-bit 1st then endmill !...then make a final judgement !!
  1. Looking for HDPE
    By Hack in forum Glass, Plastic and Stone
    Last Post: 06-10-2012, 10:46 PM
  2. HDPE
    By domar in forum Australia, New Zealand Club House
    Last Post: 12-19-2010, 10:24 AM
  3. I need to buy HDPE
    By jimmycakes in forum Glass, Plastic and Stone
    Last Post: 10-22-2008, 09:34 PM
  4. HDPE
    By cnczoner in forum MetalWork Discussion
    Last Post: 07-07-2008, 01:17 AM
  5. HDPE Bearings
    By jhowelb in forum Linear and Rotary Motion
    Last Post: 03-04-2008, 09:45 PM
