My needs are the following -
Small parts
Average Length - 1" x 3"
Thickness of Metal - 14gauge to 10gauge
Material - Stainless Steel, Nickel Silver, Copper, Brass
Engraving on both sides. Both light and heavy/deep artistic engraving
Work would include cutting part out, engraving part, and possibly rounding edges.
My initial needs are 100 to 200 pieces at time
I want the work to be done in the US
For a visual think of a heavily and deeply engraved dog tag
I have some 3-D artists and CAD folks I have worked with in the past on other projects (casting, milling, water cutting, etc.), however, I have not done the above work.
My questions are the following
- What is the file type I need for the machines? STP, DWG, etc.
- Are the file types universal, if not what is the most common type?
- With the cutting and engraving, am I asking for two separate work elements that need separate machines, or can one type of machine do this?
- Is my term "CNC cutting and engraving" correct?
- Looking through Google, I see a lot of artistic CNC wood engravings, but very few CNC metal artistic engravings. Am I asking for something that is not done?
- Finally is this something that should be done by laser vs machining?
- Lastly if you know of small machine shop that does this type of work and would be interested by all means drop me a note.
Thanks in advance. All clarifications are welcome.
JT
