585,987 active members*
4,541 visitors online*
    Nov 2009
    105
    Question Pendulum powered flywheel
    Attachment 188280
    Attachment 188278
    Hi, I started a project that will use a pendulum to drive a flywheel. I am using an over run clutch between the pendulum and flywheel so the flywheel will only rotate in one direction. The pendulum only adds power the flywheel when it swings in one direction. I am searching for a method or design that will allow the pendulum to add power to the flywheel as it swings in both directions. Suggestions welcome.
    Apr 2013
    25
    Did you try adding a gear between pendulum axis and the clutch?
    Nov 2009
    105
    Hi, sounds like a good idea. I am not sure how to do it, suggestions welcome. I am working on a rail system that will shift the weights on the flywheel. Then one side of the flywheel will always be heavier and aid in rotation.
    Attachment 190912
    Attachment 190914
    Once the weights are able to shift on the flywheel, then the power to drive the generator will come from the flywheel and the pendulum will just keep the RPM constant and keep the flywheel moving. I plan to use a solenoid to keep the pendulum power. I completed a wind turbine project but no wind no power and gravity is always on. Thanks for showing interest. Suggestions are always welcome.
    Apr 2013
    25
    looking at the video from 1st post
    you have something like this
    = axis
    ]clutch
    what if you extend the axis trough the clutch add a planetary gearing that switches direction of rotation and connect another clutch
    = axis
    ] clutch
    b bearings to support axis - optional?
    p planetary gearing
    =====]==p==]=
    ====b=]=b=p=b=]=b
    regards
    Bart
  1. How would you make a flywheel?
    By bmurph in forum MetalWork Discussion
    Last Post: 09-25-2012, 02:56 AM
  2. Pendulum Problem
    By bmelt in forum CNC Machining Centers
    Last Post: 07-01-2011, 04:51 AM
  3. pendulum
    By venomgrrrl in forum Haas Lathes
    Last Post: 05-14-2011, 12:31 AM
  4. Mike's Rodless Pendulum Clock Build
    By Mike Everman in forum Wooden Clocks
    Last Post: 12-12-2010, 04:06 PM
