The big problem is although Mazak is Mitsubishi, it is a Mazak customized system, normally with standard Mitsubishi it is usually no problem to access the PLC and build extra M codes.
IF there are any unused ones on the Mazak you MAY be able to use that in a limited fashion, especially if you just need one signal to the Robot and as UTT mentioned one input for FIN signal.
Any customization I have tried on Mazak so far, has resulted in Mazak telling me they can only be done for a fee!!
Al.
Albert E.
