585,717 active members*
4,108 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC 4020 88HS X-Y motors take jerk on startup
    Jun 2013
    62
    Hi everyone..
    I am new to fadal machines...
    I am working on a fadal VMC 4020 with 88 HS control.
    When we on the machine, all the motors X, Y, Z takes jerk on startup.
    We removed motor of X axis and checked and found motor on startup moves a little clockwise and then CCW, which makes jerk the bed with sound.
    Please help...
    Sent from my GT-I9100 using Tapatalk 2
    53
    Fadal machines do move back and forth on power up, when the drives energize. This is normal. If the axis shakes violently, that is not normal, though only AC drive machines would show this type of problem, which means either the comp needs adjustment, or as a worse case, software update and possibly new amp boards.
    Jun 2013
    62
    Thanks for reply....
    We did tuning of servo amps. Now the jerk is reduced but not eleminated.
    The main problem is the machine is used for dies.
    Long programs are running. Whenever power goes off on again power on machine takes jerk and marks comes on the profile.
  1. powermill - fadal vmc 4020 with a cnc 88hs
    By ahmed4040 in forum Post Processor Files
    Last Post: 01-08-2012, 03:02 PM
  2. NCFadal v1.3 - 95 4020 88HS question
    By Wade C in forum Fadal
    Last Post: 11-04-2010, 03:14 AM
  3. Fadal 4020 88HS IMPORT / EXPORT
    By cam280 in forum Fadal
    Last Post: 06-30-2009, 03:14 PM
  4. VMC 4020 CNC 88HS language operation
    By krzysztofz1 in forum Fadal
    Last Post: 02-25-2008, 12:02 PM
  5. Darth Vader is a Jerk.
    By Nono in forum Community Club House
    Last Post: 12-29-2007, 11:16 AM
