586,005 active members*
5,088 visitors online*
Results 1 to 7 of 7
    Apr 2008
    87
    Question Strange Chinese Material Flaw
    I have never seen anything like this before and everyone I show it too is pretty perplexed on how it even happened in the first place. I thought I would share it and see what some of you think.
    Enjoy.
    Attachment 188660
    Dec 2004
    783
    Looks like a major flaw in the casting process before machining. What material, and what is the part for?
    Sent from tapatalk
    Apr 2008
    87
    it's 6061 aluminum bar 1.250 Square. This was in the middle of a 144" length. There were 2 parts that were like this that we found, the other not as bad, at least one slipped through. You can't tell from the picture really, but the flaw is cone shaped. The hole on one end measures .340 while on the other end it measures about .825. The part is 7.775 long. It is called a Yoke, not sure of the purpose.
    Dec 2004
    783
    I could tell from the pic that the void was cone shaped, what's the surface like inside the missing chunks?
    Sent from tapatalk
    Apr 2008
    87
    It's kind of hard to describe. I will take a close up of it tomorrow.
    15362
    GM81
    The billet got to cold when it was being extruded, are you sure it was made in China, most of there aluminum bar is very good
    Mactec54
    Apr 2008
    87
    Usually we get our Aluminum from Kaiser but this size was on back order. So our supplier specifically asked if we could accept Chinese Import. I looked this morning and I don't have any rems with the name on it. That is all I have to go by. Here is a close up of the hole.
    Attachment 188740
  1. Dial Test Indicator Flaw
    By Zirok in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2012, 08:04 PM
  2. Replies: 2
    Last Post: 05-22-2012, 04:47 AM
  3. Major software design flaw, $500 lesson
    By kaibab in forum Haas Mills
    Last Post: 09-09-2011, 01:57 PM
  4. Chinese Mill + Chinese accesory + Newbee = Problem
    By csaw in forum Benchtop Machines
    Last Post: 01-24-2010, 05:39 PM
  5. Strange Chinese laser engraving behaviour
    By MicheleZicchino in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-08-2007, 02:12 PM
