I started a new job recently thus working with a older burn 10 then what I was use to. I been experiencing two issues with this machine. (1) When changing consumable heads, and loading new jobs into the system the software doesn't seem to like updating consumable amperages. An example would be ..from 80 amps to 200 amps it will stay on 80 and pierce with 80 amp settings. This is also the case with scribing. When scribing part numbers on parts before cutting the part it will want to cut instead of scribing. (2) Also recently having issues with oxy fuel cutting. When setting up to do oxy fuel cutting seems not to change the gas flows back to oxy fuel so every once and a while I can't even light a torch unless I reboot the system.
