585,970 active members*
4,439 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Blower for The Demon V8
Page 4 of 5 2345
Results 61 to 80 of 82
  1. #61
    Nov 2003
    287
    Re: Blower for The Demon V8
    Work of art. Just Awesome. Thanks for sharing
  2. #62
    Sep 2013
    147
    Did you get it running?
  3. #63
    Dec 2006
    603
    Not yet but I only have to make pistons, rods, and rings. Everything else is made.
  4. #64
    Dec 2006
    603
    Just to let everybody know, the rights to the plans for the demon V8 now belong to Executive Model Design. They purchased the rights to sell plans to those who wish to build one but to also look into producing mechanics kits for those who would like to purchase the parts and assemble it themselves.
    The pricing will remain the same for electronic copy's of the plans but an added cost will be in place for those who want printed copies. The added cost will cover ink, paper, and postage. The plans should be available soon on there website.
    I will pass off my list to them of the people who have purchased the plans from me so replacement can be made in the event of a computer crash. Anybody who wishes to purchase plans from now forward can get them at Executive Model Design.
  5. #65
    Dec 2006
    603
  6. #66
    Mar 2015
    64
    This is an awesome project. Excellent craftsmanship. I definitely want to keep my eye on this one.
  7. #67
    Oct 2006
    708
    Hi Steve
    Glad to see you are at it again. Looks just like it could be a full-size car.
    Are those parts brass, or is it just the lighting?
  8. #68
    Dec 2006
    603
    Calipers are aluminum. The rotors are brass
  9. #69
    Apr 2012
    71
    Nice work, here is One I always thought would make a real nice Model Engine the Australian Repco Brabham F1 Engine from the mid Sixties, Very sweet looking engine and considering the Full size one was based on an Oldsmobile Alloy pushrod V8 from the early Sixties and converted to a OHC F1 motor that won a few World Championships with Machinery and techniques used in the real world that are more akin to what a Manual machinist would use a CNC built one would be a good project for a Model.
  10. #70
    Dec 2006
    603
    Well i found myself with a day off from work so i made a pair of rear shocks. They are basically just like an RC shock except all brass instead of plastic. I couldn't find springs close enough to size so I wound a pair to the OD and length I needed. They were assembled and soldered together. I modeled them after the adjustable coil over drag racing shocks.
  11. #71
    Dec 2006
    603
    Finally had a chance to get something done. Made the wheelie bars They are an exact copy of some bars i found on the web.
    - - - Updated - - -
    Center section is almost complete. I still need to drill and tap the drain hole for the gear lube and make a drain plug. If I can get the gear cutting nailed down I might be able to make a ring and pinion set.
  12. #72
    Jun 2011
    695
    Amazing! I missed a lot of this update.
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  13. #73
    Oct 2006
    708
    Awesome detail, as always, Steve.
    Will the suspension dampers work by squeezing air through small holes? I ask that because I assume oil will leak out unless you have O-ring seals.
  14. #74
    Dec 2006
    603
    No holes. Air has to pass around the piston.
  15. #75
    Dec 2006
    603
    A little update on the car.
    I couldn't make heads or tails of the gears as far as the exact placements of the cuts with the custom cutters. I fully understand the article and what is supposed to happen but the numbers didn't seem to work so i freakin winded it. I patched as much of the article together with the 3D cad and drew up the gears and eyeballed the shape of the teeth and did my own thing. After a few hours of adding a little here and taking off a little there I had a set of gears that were ready to "test". My pal was going to print the gears in ABS and pass them off to me to try. Couple days before I was ready his printer died. I really needed them printed on a "good" printer with good resolution. So I searched the web and found a place that could print ABS. Come to find out the set in ABS on a really good printer costs about 75 bucks plus shipping. After further snooping on the website i found they could 3D print in steel so I had to see what that would cost. 42 bucks in steel plus shipping so guess what I did. Well they are not that bad other than a bit of a rough finish but I figure I could run them in with a little diamond paste. They don't take kindly to drilling and threading. My mounting holes were printed into the part .005 under and I had to drill to size. Drill bit got hot real fast but it worked. Tap is still pissed at me but it did take a thread. Obviously not as nice as machined gears but cheap in my opinion. I still have an interference issue that I think some button head screws will clear up but other than that everything fit as planned.
  16. #76
    Dec 2006
    603
    Put the final touches on the rear end. The center section was completed by cutting a clearance on the bottom so the mounting hardware could be inserted through the holes. The oil fill plug was drilled and tapped. The yoke was cross drilled so the Ujoint can be mounted. The entire thing was assembled complete for the first time. I also had a chance to make the front rims and the centers for the rear rims. I have 100 stainless screws on the way to assemble them.
  17. #77
    Jun 2004
    6618
    What! No valve stems?
    Excellent work. I would not have thought of using sintered gears. I am only guessing that is the process they use when printing steel.
    Do you have a link to that source?
    May come in real handy at some point.
    It is coming together nicely. Work of art.
    Lee
  18. #78
    Dec 2006
    603
    https://i.materialise.com/
    I think they are in belgium.
  19. #79
    Dec 2006
    603
    Another weeks worth!
    I have finished the front struts. I still need to make the mounts for the top so stay tuned on that. Started on the pieces Saturday so there is 5 days, a couple hours a day. Need to sort out the top mount and make the hub so I can get the front wheels mounted.
  20. #80
    Dec 2006
    603
    Well I finally have wheels on the front. I finished up the heim joints on the A arms and made the hubs. The brakes are bolted on for the first time and the tire is mounted. I am going to make a wheel spacer tomorrow to give a little more room between the rim and calipers.
Page 4 of 5 2345
  1. Steve Huck's Demon V8 version 1.5
    By cforcht in forum I.C. Engines
    Last Post: 04-25-2022, 02:54 PM
  2. Demon V8 updates, getting them?
    By stevehuckss396 in forum I.C. Engines
    Last Post: 02-08-2014, 06:25 PM
  3. Fan , blower , connection , help
    By josvanhout in forum CNC Machine Related Electronics
    Last Post: 11-03-2013, 10:40 PM
  4. Building a Little Demon V8
    By maxine in forum I.C. Engines
    Last Post: 06-21-2013, 06:21 AM
  5. Vacuum or Blower
    By stickermanstl in forum Commercial CNC Wood Routers
    Last Post: 03-04-2010, 01:38 PM
