The ATC on our Tormach has proven to be an aid in reducing production run times and freeing up the operator to do something else while the machine is running. While I can change tools manually quicker that the ATC, I have to be standing there, tool in hand, waiting to make the change.
The only hitch so far is the air blast to clean the tool shank and spindle before and during the change. This feature works very well blasting the tool shank with air. The only problem is that this air is down stream of the regulator/filter/lubricator and it does a VERY GOOD job of lubing the TTS Shanks.
The first thought is to split the air supply line and deliver air to the air blast solenoid valve directly from source. It should then also have a Regulator/Filter upstream of this valve. The supply could also be run through a Regulator/Filter to supply all air and a Lubricator added downstream after the air blast is pulled out.
Anybody thought about this or delt with it so far?
nitewatchman
