585,959 active members*
5,323 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Leaking Hydraulic Fluid From Chuck
Results 1 to 3 of 3
    Apr 2009
    12
    I have a okuma lb 15 and is leaking hydraulic oil from the chuck I assume its a seal or something by the actuator was wondering if anyone knows how to take the machine apart to get to the seals and actuator so I can inspect everything and see why it is leaking.
    Feb 2009
    6028
    Guaranteed it's the rotating seal inside the actuator. Dangerous condition right now, especially on an Okuma. Okuma shuts off the hydraulic system during an emergency stop and relies on a neutral solenoid to hold pressure. With the leak, it won't hold any pressure and that part will fly out.
    Not too bad of a job to get it off really, you need to remove the chuck, remove ring of cap screws on the actuator to spindle flange, drain and hydraulic hoses come off, prox switches and some the anti rotation bracket. The actuator will come out with the draw tube. Most older Okumas have a lock ring you can then loosen and unscrew the drawtube from the actuator.
    The actuator itself has some gotchas to repair. I know of at least one hidden screw that gets everbody the first time and breaks the casting. Also, most of the time the actuator will need to be honed. I usually send them out to get rebuilt with new bearings and seals, since i didn't want the possible injury liability on those.
    Apr 2009
    12
    Ok thanks for the help going to start taking apart if anyone else has any other advice please feel free to share.
    Thanks.
  1. Hydraulic expansion chuck vs. Collet chuck
    By gocuk in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 12-05-2011, 04:42 PM
  2. SL-20 is leaking hydraulic oil from the drawbar.
    By TXFred in forum Haas Lathes
    Last Post: 07-24-2010, 04:19 AM
  3. Okuma MA 400 Leaking Hydraulic Fluid
    By bmckelvey in forum Okuma
    Last Post: 05-20-2010, 12:25 PM
  4. Hydraulic/Air 3 Jaw Chuck
    By Hellbringer in forum Mini Lathe
    Last Post: 07-08-2009, 01:48 AM
  5. Air/Hydraulic leaking problem??
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 06-20-2007, 04:50 AM
