Hi all,
Thought it was time to share some photos of my little project.
Attachment 189478
Attachment 189480
Attachment 189482
Attachment 189484
Hi all,
Attachment 189478
Attachment 189480
Attachment 189482
Attachment 189484
The machining area will be 1400 x 2600. Servo driven on all axis. Hiwin linear bearings. Granite devices servo drives. HSD ES915 tool changer spindle. Yaskawa VFD.
Alan.
Some of the things that have been made on the first router.
Attachment 189486
Attachment 189488
Attachment 189490
Attachment 189492
Very nice.
How powerful are the servos?
Lindsay
Hi Lindsay,
The z axis has a 200 watt allen Bradley.
The y axis has a 400 watt allen Bradley thru a 10:1 bayside planetary gearbox.
And the x has two 660 watt servos from granite devices thru 10:1 bayside planetary gearboxes.
Alan
Nice looking chunk of wood you carved it on. What is that species called? I have some small boards of Sidney blue gum eucalyptus and curly wandoo eucalyptus from Australia.
CarveOne
http://www.carveonecncwoodcraft.com
Hi Carve One,
I'm not sure. I picked up a heap of wood from an old farmer in central Victoria. Australia that is.
I'm just in idiot fitter and turner.
It's not as nice as the boxes you have been making.
I left it rough on the top face to give it a rustic look. It's been epoxy coated and put in a garden.
Hopefully someone will chime in and tell us the type/species.
Alan.
Nice build, got some more photos.?
Hi Wayneb,
Not at the moment. I'm about 4000kms from home. The table has been final machined and I will have more photos on Monday.
Alan
Managed to get some wiring done last night. Mounted the 165 volt power supply and the wired up the magnetic contactors. Installed the rest of the granite devices cards and Bob.
Roughly tuned the Y and Z axis also.
But getting strange results on powering up the cabinets. The Y axis surges to the right on startup and gives a following error. The cards are VSD-XE 160 from Granite Devices. May have something to do with the hall sensing. Will investigate a bit later on.
Attachment 191136
Attachment 191138
Attachment 191140
Attachment 191142
Alan
It's that air folded 9kw etc spindle can you give use feed back about... how well it's performed
