585,761 active members*
4,185 visitors online*
Thread: Coolant Pump
Results 1 to 7 of 7
    Aug 2011
    37
    Coolant Pump
    Has anyone tryed the new HI-Flow Cooant pump up grade from Tormach 1/6 hp pump ??????
    Dec 2010
    1230
    I switched to a 3/4 hp dirty water sump in a 27 galling heavy duty tub on wheels. I had to replace the Tormach collection tray (as it overflowed on the first usage with a 2 gallon (iirc) rectangular tub. I added a pass through NPT flange and 1" pvc and tubing to return to the big tub. The tubing passes through a 200 micron bag filter as it re - enters the coolant housing.
    Everything is controlled by relays to the Tormach controller isn't handling the amperage which allowed me to add switched to my home made remote e stop. I can switch from air to flood and also flip a switch outside the machine to turn on the flood for a large line to a garden hose sprayer for rinsing chips to the drain for faster clean up before and after production runs as that is the only time I bother saving chips.
    Sep 2012
    1543
    I need pictures! All those features wrapped into one post and I've wanted to do all of them!
    I looked at Tormachs New pump, but I think a sump pump may be the way to go.
    Dec 2010
    1230
    I actually shot videos but laptop overheated twice while trying to upload the massive files. I just got a phone that shoots better video than my camera so I'll shoot some this week and upload them. Funny that I run cam, cad and professional editing software on there and the only two things that kill is are massive hd videos and Google sketch up.
    Sep 2012
    1543
    Blow it out with your air compressor, I did the other day and couldn't believe what came out, seems to run cooler.
    As for the phone, I hear ya, All my pics and vid are from a HTC Rezound phone, technology is crazy!
    Dec 2010
    1230
    I probably owe it a good cleaning. I also bought a cooling station with three seperate 100mm fans that can be positioned anywhere on the stand to get air to the hot spots and a speed controller. Laptop internal temp dropped from 151 with a dingle fan on my old lap cooler thing to 141 now with these three fans. Very impressed.
    Sep 2012
    1543
    I haven't seen that one, I'll have to look for it. Back on topic, let's see some vids!
  1. 325 Coolant Pump
    By TurtleRacing in forum Tree
    Last Post: 04-02-2012, 07:51 PM
  2. Tm Coolant Pump
    By behindpropeller in forum Haas Mills
    Last Post: 03-15-2010, 04:45 PM
  3. Coolant Pump
    By Smackre in forum Mechanical Calculations/Engineering Design
    Last Post: 06-29-2007, 07:16 PM
  4. coolant pump ???
    By Loadedagain in forum Charter Oak Automation Support Forum
    Last Post: 01-03-2007, 07:54 AM
