584,841 active members*
4,656 visitors online*
    Jun 2013
    wire edm lower head trouble
    I have a Mitsubishi wire edm ( FA 20s advance control ) having issues with the ceramic piece in the lower guide D, clogging up with what appears to be shavings from the brass wire, not allowing threading. I use the same wire on two FA 10 wire edm's with no trouble. Any suggestions on what would cause this ?
    Mar 2013
    10
    change your flushing settings. or check you have enough pressure to push the chips out.
    Dec 2012
    108
    Have you checked your carbides to make sure that they are not "shaving" your wire? If you change wire diameter from a larger to a smaller diameter it could also be scraping off small pieces of brass, or you could have a deep groove possibly?
    Dec 2012
    Check whether there is any flaws on the Electrode Pin (Power Feed Contact), also if you been cutting large tapers, make sure you not exceeding recommended taper angle for your lower wire guides and inspect for any damage especially for tiny rust particles that jam up and bond to the diamond guides.
  1. Fanuc 1b wire edm Trouble
    By pgodell in forum EDM Discussion General Topics
    Last Post: 03-13-2013, 04:43 PM
  2. Wire To Plasma Torch Head
    By travmc1 in forum Waterjet General Topics
    Last Post: 04-30-2012, 12:12 PM
  3. nail head on .026 ss wire
    By dlaery in forum Diemaking / Diecutting
    Last Post: 12-29-2011, 03:44 PM
  4. Wire EDM motor trouble
    By sparky212 in forum CNC Machine Related Electronics
    Last Post: 01-08-2010, 06:02 PM
  5. power head to raise and lower non cnc
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 01-05-2008, 07:32 AM
