585,764 active members*
4,144 visitors online*
    Feb 2013
    Load Monitor on (or not)
    Is there a way to alarm Mori Seiki ZL253SMC lathe out if Cycle is started with Load Monitor not turned on? Maybe with a macro? Call a macro in the first line of code to check if On, then alarm and message if not on? How would that be done? Thanks!
    Aug 2011
    2517
    load monitor is turned on in the program. so just add the commands to the program......
    Feb 2013
    It is in program, but if it is not set to monitor on the settings page it is not monitoring. That is the page where teach/monitor are shown. Want to verify its on and not in teach mode.
    Aug 2011
    2517
    I don't think you can check that. there is a macro variable that is flagged 1 when the load monitor is in warning mode (#1001) but nothing for the actual monitor mode. you might need to go higher and consult Mori Seiki.
    maybe you can hire smarter operators so you don't need to check whether it's in monitor mode? ;-)
    Jun 2011
    124
    Hey fordav! Sounds like hes running my old machine!!!! Ha!
  1. Load Monitor
    By ChattaMan in forum Okuma
    Last Post: 12-19-2011, 08:10 PM
  2. Spindle load monitor on Makino MC-100
    By swarfy in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2010, 08:54 AM
  3. Hurco VM1 Spindle Load Monitor
    By MidFloridaTech in forum HURCO
    Last Post: 11-22-2007, 07:15 PM
  4. monitor
    By CASTLEVILLE in forum Bridgeport / Hardinge Mills
    Last Post: 10-11-2007, 12:37 AM
