585,883 active members*
5,280 visitors online*
IndustryArena Forum > CAM Software > CamBam > Just Downloaded CamBam
    May 2013
    24
    Downloaded Cambam yesterday onto my CNC box. It runs Windows Vista. Everything seems to work as advertised...except
    for producing G-code. When I click on "Produce gcode" in the machining menu...it does nothing. Does the evaluation version
    not allow you to produce any gcode. The drawing is a very simple one...nothing long or complicated there. Any help???
    Jim
    Have you created toolpaths?
    May 2013
    24
    Tried to create toolpaths, but same result...nada. I guess a better question I need to ask is "What do I have to define before I
    can generate toolpaths or gcode?
    Jim
    Apr 2007
    663
    What CAD program did you use?
    Is the object you designed 2D or 3D?
    What format is the file you imported to CAMBAM?
    Is the "normal" side up?
    Does the object show up on the computer monitor within the CAMBAM screen?
    Did you EDIT>TRANSFORM>ALIGN the object to the X,Y, Z axes?
    Nov 2008
    644
    Put something simple on the cross hairs like a box
    click on the box then hit choose machining in the upper menu then choose profile
    in the upper right tree click on machining
    go the bottom of the parameters in the lower left box and click on post processor
    choose something like Mach3
    So the reason you didn't get anything is because you didn't define the machine its trying to create gcode for
    then click on machining in the upper left tree
    Then right click produce gcode
    it should then ask you where you want to save it to and you should have a text file with gcode
  1. EMC and CamBam
    By helpmeout in forum LinuxCNC (formerly EMC2)
    Last Post: 12-14-2011, 02:49 PM
  2. Just downloaded Mastercam X5 Need Help
    By Eddieman in forum Mastercam
    Last Post: 07-18-2011, 10:35 AM
  3. I have downloaded them all, now which one?
    By replicapro in forum Uncategorised CAM Discussion
    Last Post: 06-24-2004, 06:34 PM
  4. I downloaded a demo
    By cncman in forum Uncategorised CAM Discussion
    Last Post: 06-17-2003, 09:38 PM
