585,717 active members*
3,976 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Incomplete slot with MGV milling on Maztrol T Plus control
    Jul 2013
    4
    Hello all. In programming a part with a oval keyway in the OD to run on a Mazak 18-MSY mark 2 with a Maztrol T Plus control.
    I'm using the MGV milling function, trying to cut a .408" wide slot with a .313" endmill. My slot looks 95% complete, but one end of the slot has an incomplete radius. Instead of a full radius blending smoothly into the long straight walls, one corner has a distinctive blend mark from a smaller radius. If I were programming in EIA, I would think that I inadvertantly turned tool comp off too early, because the endmill seems to be pulling too tight a turn going into the last corner of the slot. The resultant radius measures about .360", which is not the tool or the programmed part geometery.
    My process parameters are as follows:
    MODE: MGV OUT
    Mode #: 3-0
    GRV-WID: 0.408
    DEPTH: 1.08 (through the part)
    FINISH: .010
    RV: 120
    FV: 180
    R-FR 1: 0.0008
    R-FR 2: 0.0005
    R-TOOL: 9
    F-TOOL: 9
    SEQ:1
    SPT-R: 0.535
    SPT-O: -90.0
    SPT-Z: 0.625
    FPT-Z: 0.640
    ROUGH: .001
    Any idea why this slot is not comming out oval? I'd program it as a MMP (Manual Milling Process), but I only have +/-.0025 on the slot width, and then the operator would need to edit the program to size the slot instead of comping the tool diameter. I'd like to avoid that. Any help would be apreciated.
    Dec 2007
    300
    I would check the parameters for ramp in and out. That is a pretty tight fit and big clearance will cause some problems with entry/exit. Check U3,U4,U5,U6. Change them to .005 with TPC and see if that helps.
    Jul 2013
    4
    Thanks MrMazak. That advice definitely got me looking in the right area. What I thought was an incomplete slot, upon further inspection, was actually being undercut in one of the corners as the endmill over-shot the far end of the slot before pulling out. I dug thru some books, and it turns out that user parameter U14 controls how much overlap there is on a Y-axis milling path to ensure a smooth transition from the start to the end of a cut. My machine was set U14=787 or .0787" of overlap. That's a problem when my slot is only elongated .015". I set U14 to 100 (.010") and my slot looks oval again. Thanks again for the timely help.
  1. T-slot milling
    By Lene Madsen in forum EdgeCam
    Last Post: 11-12-2012, 08:51 AM
  2. BobCAD v24 t slot milling
    By Tkamsker in forum BobCad-Cam
    Last Post: 11-25-2011, 11:08 AM
  3. Milling Slot in 1010
    By gpraceman in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 06-24-2010, 01:41 PM
  4. Milling slot , but not smooth
    By Tony Chen in forum Community Club House
    Last Post: 06-23-2010, 06:23 PM
  5. Milling Slot in Aluminum
    By gpraceman in forum Community Club House
    Last Post: 06-20-2010, 12:53 AM
