Stone engraving machine is mainly used in the engraving of the hard materials such as marble. granite, glass. stone etc,
Marble CNC router
Stone engraving machine is mainly used in the engraving of the hard materials such as marble, granite, glass, stone etc
Adopt Taiwan Linear guide rail. The bearing of the lead guide rail is face to face, the long time use precision is high
Germany double nuts automatic ball screw
High speed driver, high speed, high power
No dust oiling structure, guarantee the long term running of the mechanical aspect
Break point and break knife continue engraving function, can engrave at any place as you like
The compatibility is high, CAD/CAM software such as Type3/artcarm/castmate/proe/Corelerow/Artcut
High power frequency changing water cooled spindle, can process hard materials efficiently
There are working size 600*800mm, 900*1500mm, 1200*1200mm, 1200*1800mm, 1200*2400mm, 1300*2500mm, 1500*3000mm, 2000*3000mm, 2000*4000mm for optional
Technical Parameters:
Machine Model COM-9015ME
Cylinder Marble CNC Router
Work Travel 900*1500*420mm
X,Y Transmission X,Z Linear Guide Rail, Y Round Rail Gears Rail
Rotary Working Size 300mm*1200mm
Max Cutting Thickness 35mm
Spindle motor 3.0 KW Water-Cooling
Software TYPE3 (English) /Artcam
Operation System DSP 0501 Control System
Driver Stepper Motor LEANSHINE
Spindle Speed 0-18000 RPM
Max Speed 20000mm/min
Max Working Speed 10000mm/min
Working Voltage 380V 50HZ/60HZ
Blade Diameter 3.175mm,4mm,6mm(or 8mm,12.7mm)
X,Y,Z Traveling Positioning Accuracy ±0.03/300mm
X,Y Resolution ﹤0.025mm
N.W 1500KG
Packing Size 2300*1660*1870mm
Delivery Date 25 working days
quote from buy cnc marble router - high quality Manufacturers,Suppliers and Exporters on weiku.com
